Request VIN Lookup Thread
rugedraw
Javier
Miami
Auto Sales
Please tell me when (and why) my last update failed?
1FTMF1E51MKD79546
And thanks!
It failed four days ago and the error code is "DiffEngineFailed". I do not know what that means, but it seems like it failed to download one of the files needed for the update.
Ford F-150 Request VIN Lookup Thread 1718648424597-ql
bkuhl
Benjamin
Colorado Springs
2023 Ford F150 Lariat (M) Powerboost
I don't know anything about the truck really. Just picked it up a little over a week ago and it's in the shop waiting to be looked at for the aux pump issue.
Would love to know SW status and if possible, BLEND/BUILD date. No window sticker was provided when purchased. Thanks in advance!
1FTFW1EDXPFB39053
2023 F150 Lariat (M) Powerboost
/r,
Benjamin
Lost in the sauce, perhaps. When you get a chance, can you check me out?
rugedraw
Javier
Miami
Auto Sales
Most likely. Build date 3/23/23. Window sticker is attached.
Last OTA was 6.1.0 about a week ago. Truck is on Sync 23045 which is two version behind the latest, so are missing more than a few updates to be fully up to date.
rack04
Justin
2021 Ford F-150 Powerboost
Would appreciate someone checking to see if I have any module updates available in FDRS. I have some time this weekend and may fire up FDRS to perform any updates. Thanks.
mau47
Northeast
23 F150 502A Powerboost FX4
Could someone kindly pull the DTC history for my truck and if you are willing print to pdf? I have a trip to the dealer on Thursday about an issue with cameras and wanted to get the latest that has been logged as it was throwing two codes fairly regularly last time I checked.
1FTFW1ED5PFA51155
Thanks
rugedraw
Javier
Miami
Auto Sales
Would appreciate someone checking to see if I have any module updates available in FDRS. I have some time this weekend and may fire up FDRS to perform any updates. Thanks. 1FTFW1ED6MFB86236.
You're only showing updates for the door modules. Save the $50 for something more exciting.
May I get a VIN Lookup for OTA updates please: 1FTFW1CD8MFB61759
Your truck is on the latest Sync version, but it is showing many of the ancillary updates still pending. Last OTA you got was a DSP update 5-6 weeks ago.
Ford F-150 Request VIN Lookup Thread 1718662008204-xa
1FTFW1ED5PFA51155
Thanks
Pdf is attached.
jbruize
2021 F150 XLT
OTA history is below. Last OTA sent to you was 22-PU1009-TLC-CSM2 which failed several times due to low battery voltage. Nothing has been sent since then.
Thank You!
Nothing has been sent to you since 23-PU1009-SS-NS went through in April. If you are seeing a message of a pending update, you can ignore it. These phantom update messages are being commonly reported.
Mstephens20
Matthew
Clearwater Fl
2021 F150 PB Platinum FX4
1FTFW1ED9MFB06427
Rugedraw, can you check my vin again for any other updates. I came across this today in FordPass and wonder what it’s referring to. As far as I know my bluecruise has been working fine.
Thanks!
Ford F-150 Request VIN Lookup Thread IMG_4894
rugedraw
Javier
Miami
Auto Sales
1FTFW1ED9MFB06427
Thanks!
Ignore it. My VIN still shows that campaign open and I've had BC for years.
robry
Ryan
State College, PA
2023 F150 Tremor 5.0
Since my FDRS is expired I can't just look at what updates are sitting out there. Any chance you can check to see if there is something out there for my vin? 1FTFW1E55PFA59040
Knuckleb72
Brandon
Chatsworth,Ga
2021 F150 CrewCab Sport 4x4
1FTEW1EP1MFA48853 Can you check mine please having issues with collision and abs warnings
TheMask
Abdullah
Oman
F150 Raptor 2023
Hi All, I just purchase used 2023 f150 raptor with very low milage. I tried to activate ford pass but no luck so far. I am deciding to go for Mongoose and try to update it via cable. I am setting on Sync 4.0.23031 as of today and wondering what I am missing so far, if some one could check that for me please.
VIN : 1FTFW1RG5PFA56795
rugedraw
Javier
Miami
Auto Sales
You're showing updates for the door modules, HVAC module and PCM. Nothing worth $50, imo.
Yea, you truck is reporting several codes that have several SSM's and TSB's tied to them. This is something the dealer is going to have to look into.
Ford F-150 Request VIN Lookup Thread 1718725558196-wr
The modem on this truck has not been activated. I would need to check your VIN in FDRS which I don't have access until later. The list below is what PTS shows you have pending to update, but there should be more.
Did you buy it from a Ford dealer?
