Request VIN Lookup Thread
Boocie
Joshua
Davenport, IA
2021 Ford F-150 Supercrew Lariat
Sales Engineer
VIN : 1FTFW1E88MKD64755
Thanks!!
rugedraw
Javier
Miami
Auto Sales
Thanks!!
Your truck is on Sync 23159 which is one version behind the latest. Last OTA was a minor GWM back in April. Your truck is fine; you're a bit behind, but nothing to be worried about. The reason you are behind is because the OTA process is not great and not because of any issue with your truck.
Jknapp1
Jeff Knapp
Birmingham, Alabama
2021 F150 Powerboost
Elevator mechanic
1FTFW1ED8MFB24093
Maybe take a quick peek under my skirt??
rugedraw
Javier
Miami
Auto Sales
1FTFW1ED8MFB24093
Sure. Let me stick a little mirror between my shoelaces like back in elementary school. :ROFLMAO:
Looks like the 3rd time was a charm with your APIM's. You got OTA 2.6.0 in March, but nothing has been sent since then. As far behind as you are, I would consider FDRS because it will take a veeeeeeeery long time for the OTA process to get you caught up.
Jknapp1
Jeff Knapp
Birmingham, Alabama
Elevator mechanic
Thanks ruge!
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
@rugedraw Can you please check out if there is any available updates in FDRS for my truck.
VIN# 1FTFW1E51MFC37912
Thanks in advance, really appreciate your effort and help.
rugedraw
Javier
Miami
Auto Sales
You are not showing anything pending in FDRS.
Hans Moleman
SF Bay
Ford does pay them to update modules just because they aren't up to date. They usually just tell that to people to get them to leave them alone.
Ok so I just looked over the service notes and it doesn’t match with what the service advisor verbally said.
When I initially dropped my truck off for an oil change I told the service advisor about getting random trailer brake fault error messages. When I picked it up the service advisor verbally said the tech updated every single module that had new updates available.
However the service notes actually said the tech performed module updates per TSB 24-2116 which is only for the APM, GWM, and TRM modules. Then it said the tech only updated the GWM module because that was the only module that had updates available, and the APM & TRM modules already have the latest updates.
I actually did not ask the dealer to update all of the modules, I just said I was getting a trailer brake fault error message. But I guess the service advisor was a little excited and stretched the truth a bit. :facepalm:
rugedraw
Javier
Miami
Auto Sales
The service advisors are usually clueless as to what the techs actually did.
Paul Neubauer
Paul
Is their a way to see what the IQA values are on the diesel injectors that are installed in my engine from the factory in PTS or FDRS? I had a recall to enter the correct values but the invoice shows "no program available". My vin is 1FTFW1E13MFB77676.
jbruize
2021 F150 XLT
Looking for another VIN Lookup. I believe my low voltage issue is fixed, but I have not seen any updates push though since then so I am wondering if there are any updates available for my truck.
1FTEW1EP2MFA63202
Thanks!
Trey50z
Trey
Los Angeles
Honda Pilot
My 21 Lariat seems to be stuck on an update that claimed to have been installed successfully. However, I keep seeing the same OTA update come in.
Can someone look at my OTA for VIN: 1FTFW1E88MFA52931
TIA
rugedraw
Javier
Miami
Auto Sales
1FTEW1EP2MFA63202
Thanks!
OTA history is below. Last OTA sent to you was 22-PU1009-TLC-CSM2 which failed several times due to low battery voltage. Nothing has been sent since then.
Ford F-150 Request VIN Lookup Thread 1718645681359-4a
TIA
Nothing has been sent to you since 23-PU1009-SS-NS went through in April. If you are seeing a message of a pending update, you can ignore it. These phantom update messages are being commonly reported.
BellaDonna
RDavid
14988 Genesis Rd
2021 F150 XLT FX4 5.0 Std Cab Short Bed Antimatter
Retired Cyber Security Engineer
Please tell me when (and why) my last update failed?
1FTMF1E51MKD79546
And thanks!
Trey50z
Trey
Los Angeles
Honda Pilot
Thank you. It's probably phantom update.
