timnohio
- Thread starter
- #1
Newbie here!
IHC Ride Quality 3/5 Kit will be here next week for my 2024 RCSB 4x2.
I've changed some suspension parts in the past, never lowered one. A friend of mine that has put 2 different lowering kits on his Mustang (different animal, I know) will be doing most of the work.
I got a quote from a local Ford dealer. Here is his email.
"Youd be around $1917 for labor, also if you have a regular cab truck, you may run into driveshaft clearance issues with the IHC kit"
That's question #1. Anyone have driveshaft clearance issues? And where would it rub if it did have issues?
Question #2. Is it wise to install caster and camber bolts in the lower control arm while it's off? If it is what is the best set?
Question #3. Torque pre-loaded suspension...
I've seen a few different ways people do it. We'll be working on the floor of a garage. So, I'm thinking the best way is to put 2 jack stands under rear end (easy peasy) but the front....jack stands will be on the frame, so jack up the lower control arm until it's slightly starts lifting truck? Or put a jack stand under lower control arm?
What is everyones method on this?
I think that is all of the questions this newbie has.
I appreciate it.
I appreciate it.
