EL5_Zero
- #46
So far, I have a little over 4K miles on the truck, 3.5K miles since installing the IHC Performance 3/5 lowering kit with 22 x 10 Forgestar X12 on 305/40R22 tires. Over the last 4 weeks, I have adjusted the shocks and tire pressure to get a good feel on the adjustability of the suspension. It's quite surprising just how much of a difference 1 click makes on the QA1 shocks. So far, to me the best overall suspension setting for street driving is Front 38 psi with C-4 / R-5 & Rear 35 psi with C-2 / R-1 and traction bars set with 1/4" gap. I also added a bump stop and 2* axle shims similar to the ones that come with the Ridetech lowering kit.
All in all, the truck drives and looks how I expected. However, since day one I have had a vibration at speeds above 70 mph. Like most, I went down the rabbit hole of trying to eliminate all vibration. I was told by many on this forum that it was the "junk IHC Kit" that was causing my issue. Sure, I added a shim and bump stop, but this is expected when fine tuning a kit. I'm glad to say I have 100% REMOVED ALL ADDED NVH, and the truck is back to OEM levels.
Yesterday, I drove down to the same tire shop that mounted the 22's, and I had them mount and balance my stock wheels. Two wheels took .5oz, and the other 1oz to balance. As soon as I got up to highway speeds, the difference was night and day. Smooth as silk with the stock steel wheels. The issue on my truck is the aftermarket wheel / tire setup.
Today I have an appointment at Americas Tire. They have the road force balance machines. The wheels where previously balanced on a traditional wheel balancer, and I personally saw them zero out the wheels. However, they were not Road Force balance.
I will report back this afternoon with the results. Hopefully the technician is fully train on how to operate the equipment.
