Gwill30
- #16
Well....
Finally got the front end figured out.
I slotted the frame about a qtr inch and used the spc camber kits.
Dead on now.
I bought the tires plus lifetime alignment.
Been there 4 times now.. lol.
I picked up a weird vibration from 27-30mph.
Vibration started after I had it in the dealership for a coolant leak and to check on the peddle vibration.
Dealership said they felt the vibration at the same mph but nothing in the peddle at 58 like I experienced.
My driveline angles I believe are dead on.
I've watched and read a million articles and videos.
My angles.
Engine transmission transfer case is -4°
Driver shaft -1.7°
rear diff. -4°
Operating angle is 2.3° front and rear.
Dealership recommend I shim the transmission a half inch bit then also said I was within factory spec of 0-4°.
They also recommended re indexing the drive shaft. Mentioned another whipple f150 with the ridetech kit had a similar vibration and spinning the drive shaft 180° fixed that one.
I know some recommend an extra degree or 2 for leaf spring cars but im torn on where to go next..
Dead on now.
My angles.
Driver shaft -1.7°
rear diff. -4°
