Oil change
Bhartwick1
Brad
Jasper, IN
‘22 F150 XLT; ‘16 F150 XLT
Sales
Ok, I kinda feel a bit silly, but I would rather be safe than sorry. What aftermarket oil filter does this 2022 engine take. I have a 2016 also, but it seems that it’s not the same filter, at least by what K&N shows. (They don’t show one for the 2022) Is it the same engine design as earlier models? Any recommendations on oil type. I usually use full synthetic whatever viscosity is recommended. Thanks guys!
tbinmd
22 KR F150
As long as you have warranty stick with the motorcraft filter. FL500S
EricR
Eric
Boise, ID
Use a high quality / reputable brand filter.
It is illegal for manufacturers to deny warranty due to aftermarket market parts being used. Unless they can prove the specific part used was the direct cause of the failure.
For instance, Ford can deny warranty repair if your engine seizes due an aftermarket Fumoto quick oil change valve failing* and rapidly draining all the oil onto the road.
* I have no idea if any such valves have ever failed - it is just an illustration.
boo radley
ed
KS
1987 F150 1992 F150, 1999 F150, 2004 F150, 2013 F150
Mobil 1 oli filter is what I use with Mobil 1 synthetic. The 3.5 eco uses 5w - 30.
I change every 9000 miles.
Uncorked
NE Florida
2023 F-150 XL
If you really want to go down a rabbit-hole, OP, the Bob Is The Oil Guy forums are interesting.
Je1279
Jared
Upstate NY
While I agree with @EricR when it comes to the majority of modifications, the oil filter is a critical component of the engine and it is not worth risking a denied warranty claim after a major failure due to an aftermarket filter.
Uncle_Booty
Glen
Knoxville, TN
2023 F150 XLT 302A SCrew 5.0 157" 4x4
Commercial Truck Leasing
Agree, especially when the quality of the MC FL500S is so good.
nrmedic
NC
2022 F150 PowerBoost 302A; 2023 Tacoma TRD Pro
FoMoCo FL500S is below average at best, I won't use them. The micron (u) filtration rating is far from great, 80% at 20u, nope, not for me. I'll keep my Champ XL's or something with 99% at 20u.
Ummm, there's more to a filter than just micron rating.
In fact, flow is a very important aspect as well, and arguably is in opposition to filtration.
Too much of either negatively affects the other.
I'm not saying that the Motorcraft is the be all and end all, but it's actually a Purolator filter and regarded as much better than "below average" filter.
KGBOTR2
Kevin
Arizona
2022 Ford F150 4x4 RCSB
I just read in the Ford Service manual for my 2022 F150 with the 5.0 engine the the oil filter is NOT to be lubricated. Has anyone ever hear about this?
1. NOTE: Do not lubricate the O-ring seal.
Install a new oil filter.
Torque :
Stage 1: 44 lb.in (5 Nm)
Stage 2: 180°
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Torque :
Stage 2: 180°
I've seen that on other vehicles for the official procedure as well. Best guess, putting oil on the seal allows you to over torque the filter very easily.
Uncle_Booty
Glen
Knoxville, TN
I've never had an issue doing it the old school way. Lube the seal with fresh oil and turn 3/4 to 1 full turn after it makes contact. For me, that's hand tightened.
My 2ND Ford
Ny
Actually, putting oil on the o ring allows the ring to seal without twisting and tearing the o ring. Putting the filter on hand tight and turning it 3/4 turn after contact is usually sufficient.
