Ajzride
Ajzride
Automation
Ok need some help. Got everything installed this morning and everything worked great on my first two drives. I originally installed experimental and realized that was out of date so installed stable. It wouldn’t let me do it by selecting target branch and switching so I reset the device and installed using the url. Since then when I drive it just stays on the main dashboard then the screen shuts off. On the left of the main screen it shows vehicle online. I’ve reseated all connections.
Any suggestions?
If it doesn’t go from the main screen to the camera when you start the truck that means it isn’t detecting the ignition signal. It’s a wiring issue 99% of the time.
m_bt54
Bryan
Massachusetts
IT Director
thanks. That was it. I am using the short cable that came with it as mentioned before while I wait for what I need to come in. It worked fine that way earlier. I just bypassed the mount and put the long cable right into the device and it’s working perfectly now. Thank you!
Ajzride
Ajzride
Automation
Coudl be an issue with the mount. I usually test them all before I send them out, but with the christmas rush, I might have missed one or two. I have had a bad USB coupler before. If the long cable into the dock and then the short one into the comma creates issues, then I can send you new couplers to glue in.
m_bt54
Bryan
Massachusetts
IT Director
Thanks. I’ll keep a close eye on it over the next couple days and let you know if I have an issue again
Spiffy
Usa
2022 platinum powerboost
I'm currently doing a ton of backlogged update with fdrs. I understand that blue cruse 1.4 is being installed and I have the forscan changes.
I use blue pilot and run in ACC mode. Will I see anything different? Presently I have my comma completely removed because it blocks half the databuss even when disconnected from the comma itself.
Ajzride
Ajzride
Automation
Ping Pong should be completely gone after the last PSCM update.
m_bt54
Bryan
Massachusetts
IT Director
I have the newest PSCM but had to roll back to the last IPMA because the new one broke lane centering and BC. With just the new PSCM I saw zero ping ponging on my Comma 3x on the latest Bluepilot staging 1.1. I am honestly amazed how well everything works compared to Blue Cruise. Amazing work!!
Spiffy
Usa
How did you roll back ipma?
m_bt54
Bryan
Massachusetts
IT Director
Had help from Jesse. We tried everything possible to fix so those impacted didn’t need to roll back but nothing worked unfortunately. Hopefully a future update fixes it but for now there isn’t much difference between the current IPMA and one version before it.
Spiffy
Usa
What did Jessi have a copy of the past version?
m_bt54
Bryan
Massachusetts
IT Director
Luckily yes. If you end up having the issue we will be able to get you rolled back. I have done it 3-4 times now due to intentionally breaking it a few times to try various fixes.
m_bt54
Bryan
Massachusetts
IT Director
Don’t worry about it unless it’s an issue.
Exactly. Also don’t worry about it being an issue. Anyone who has been impacted that has mentioned it here is no longer impacted.
Spiffy
Usa
Are you implying that once I reinstall my comma and update to bluepilot 2.0 it will not be a issue no matter what? How did the people that were impacted get resolved without your assistance?
m_bt54
Bryan
Massachusetts
IT Director
I don’t know that I made sure I was in a known working condition when I installed my Comma so I wouldn’t have to ask too many questions (despite that I did still ask @Ajzride a lot of dumb questions!).
If your Blue Cruise and lane centering aren’t working you can try your Comma / Bluepilot but I can’t say either way if it will work. If it is working it should 100% work.
Are you having issues after the IPMA update or no?
