BLoflin
- First Name
- Brooks
- Joined
- Feb 20, 2021
- Threads
- 3
- Messages
- 388
- Reaction score
- 418
- Location
- Austin, TX
- Vehicles
- 2022 KR PB 6.5'
- Occupation
- retired
This question (about not connecting PowerBoost ground to home wiring) come us a lot.
First let me state, I'm not a lawyer, or a doctor or work for UL.... so any actions you take based on my "opinions" I am not responsible for.
Most of the safety codes for home wiring are for SAFETY, not for function. As a metaphor, you do NOT need to wear seat belts to drive (functionally, of course they are required legally in the US). Seat belts do not make driving better or easier, etc. They are there in case of a "problem" that is not the normal use (i.e. accident/rapid deceleration).
Not connecting the GND wire from PB to house, will not affect the normal use scenario (and obviously it allows (by defeating the GFCIs) normal usage.
(BTW, GFCI are also a SAFETY device not needed for normal use scenario, it is to protect against a problem/fault).
So without the GND in the PB (which is tied to the truck frame), if there was a fault scenario (with something in the truck or connected to the truck A/C outlets, a scenario like a frayed connection or one with moisture intrusion, or carbonized connections... that cause some amount of current to be carried by the GND in the PB), you have basically taken the safety measures out as the GFCIs in the truck won't sense (until the current is flowing thru you, if you are touching the truck and are grounded (i.e. standing on wet ground or holding on to a metal fence post or a natural gas line, etc). You are then counting on the breakers (and possibly the GFCIs) in the home to trip, which may be enough delay before that happens, to be most unpleasant for you (if not deadly).
There are probably other scenarios as well.
P.S. as way of an anecdotal story (but one that I actually knew the family, this is NOT an "internet story), a very sad story. Family was out doing outside chores around the home on a nice day. Washing the cars. Doing yard work. Some of the yard work tools were A/C (in this case the leaf blower). For convinence due to the length of the extension cord and the location where the husband was working, he ran the extension cord thru the front door and plugged into an inside wall circuit (i.e NOT GFCI'd). The wife was picking up as they were about done. A small portable tool chest was in the driveway as they were using tools out of it. She went to close it and bring it back in. Didn't see the extension cord was draped over the back edge. As she closed it (standing on the wet driveway from the car washing) the back of the metal toolkit lid pinched the extension cord and shorted it. She was electrocuted (yes died). Husband was of course racked with guilt. He just didn't understand there was a difference between inside outlets and outside outlets as far as Code Required safety measures (i.e. GFCIs). Just a very freak accident and scenario that ended very sadly.
TLDR: disconnecting GND in cord from PB to house circuit will not affect normal function, but you have eliminated some SAFETY measures, that under some problem/failure/fault scenarios could cause serious harm.
