Musclez
Marco
NJ
F150 14th Gen
I ordered a Lariat with front row bench seat and just realized it does not come with heated steering wheel. Granted it’s a first world problem I’d be very interested in getting it installed afterwards.
anyone in the same situation and have made any attempts?
Update:
I haven't done it myself yet but looks like our fellow members have found the solution here.
I'm still in the progress of digesting everything and I'll post updates as I go through the entire thread.
DM me if I'm missing anything.
Things you will most likely need to complete the retrofit:
- A Steering Wheel that supports the heated steering wheel (HSW) feature, some with the HSW delete from factory may already have the HSW itself just missing the control module.
- A Steering Column Control Module (SCCM) that can send power to the HSW. e.g. ML3Z-3F791-BB (you highly unlikely have it in place if no HSW feature from factory).
- Harness(es) with appropriate wiring/pin out (some already have them in place).
- (optional) HVAC control panel that has the heated steering wheel button. Part no. ML3Z-19980-K ford replacement parts or ML3T-18C612-DE.
Alternatively you can program your head unit to show a soft button on the screen.
- FORScan and appropriate coding.
From what I understand the procedure should be as follows:
1. Make a backup of as built values in FORScan
2. take the airbag off to check what parts/harness you currently have, this is because some may already have the heated wheel in place and just missing the SCCM due to chip shortage.
3. check if the harness/pins are already in place
4. purchase necessary parts for the retrofit
5. install, load factory as-built values into SCCM (and HVAC), make appropriate changes to allow HSW to work.
FORScan coding: https://www.f150gen14.com/forum/threads/heated-steering-wheel-retrofit.6022/post-293022
Factory parts list: https://www.f150gen14.com/forum/thr...fit-updated-with-information.6022/post-294458
Or
https://www.f150gen14.com/forum/thr...fit-updated-with-information.6022/post-274953
Harness:
https://www.boostedgreygoosedesigns...-2022-ford-f150-heated-steering-wheel-harness
Websites to source parts:
https://www.tascaparts.com/
Coding for soft button
https://www.f150gen14.com/forum/thr...fit-updated-with-information.6022/post-271300
Hardware video walk through for steering wheel and SCCM
https://www.f150gen14.com/forum/thr...fit-updated-with-information.6022/post-283382
Video/pdf showing how to swap HVAC control module
https://www.f150gen14.com/forum/thr...fit-updated-with-information.6022/post-408466
Retrofit on an XLT 302A
https://www.f150gen14.com/forum/thr...fit-updated-with-information.6022/post-424031
FAQs:
What does "active steering" mean?
https://www.f150gen14.com/forum/thr...fit-updated-with-information.6022/post-323800
How to configure head unit as super duty to show the climate side card?
" Using Forscan and under the easy config for the APIM, change the vehicle type from F-150 to super duty is the easiest way. " - credit to superfordman
https://www.onlinefordpartscatalog.com/oem-parts/ford-dash-control-unit-ml3z19980k?c=az0x
I can’t seem to find the harness anymore I wonder if the 250 one works?
FORDTEXAS
2022 F150 LARIAT
I'm not sure if this will work or not but instead of replacing the HVAC controls for the HSW button, you guys could try enabling the soft button in Sync with the following in FORScan:
APIM 7D0-02-02 xxx* xxxx xx--
APIM 7D0-02-01 xxxx *xxx xx-
isn't that called the unreal theme or something like that?
FORDTEXAS
2022 F150 LARIAT
ML3Z-3600-RA
my truck has the automated lane centering and lane keep assist...
can somebody strongly confirm that is indeed the correct steering wheel i need?
Micho523
Jaime
Atlantic Beach FL
2023 Lariat 502a
ML3Z-3600-RA
Adaptive steering was only an option on the platinum and limited. The number you listed is the correct one
eta: the wheel is currently on backorder, but the price has come down drastically.
skohler
Steve
Gettysburg, PA
'23 platinum PB
I've read through this monster thread a few times over the last few months debating if it is worth doing. I have a June built '23 plat and am curious if I am likely to have any of the necessary parts already- like a heated steering wheel. Anyone run across these already installed and just a SCCM needed?
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Seems like a good chunk of the later built 23's are all prewired to the SCCM so that makes it easy. For you though, you need to figure out if you have adaptive steering or not since you have a platinum as wheel and module will be different for both.
skohler
Steve
Gettysburg, PA
'23 platinum PB
I'll have to look to see what adaptive steering is, I have the usual BC and lane centering- but guessing this is something different. I don't recall having to think about it when I ordered as I did with the other options, so will have to do some digging. Appreciate the response.
If I remember right, a few folks on this thread talked about already having a heated steering wheel when they dug into this mod, guess I'll just have to take mine off and see what is there.
Edit- after looking up what adaptive steering is, I'm pretty sure I don't have it.
Brad34
Minnesota
2021 F150 XLT 302a 3.5 Ecoboost Screw
Got the new HSW installed in my '21 302a today. Everything seems to be working great. JScaro's harness and included instructions were a huge help, as was Scott Maxson's 302a specific instructions posted by fayby. The YouTube videos helped a lot as well.
Even with the 302a specific ForScan instructions, I had to make some adjustments for my specific truck. Some of my original values were different, but JScaro's instructions helped me sort through it.
mkinttrim
Soldotna, Alaska
2021 Lariat 4x4 501a
Hi all, 21 Lariat 501a looking to add the heated wheel. However I'm on my 3rd APIM and still no updates. If I add this does it mess with the APIM?
Also are these all the parts I need?
1. ML3Z 3600 RA - STEERING WHEEL ASSEMBLY (Heated steering wheel)
2. W721079 S437 - BOLT AND WASHER (Steering wheel bolt & washer)
3. ML3Z 19980 K - CONTROL (HVAC module assembly - with heated steering wheel button & digital temp display)
4. ML3Z 3F791 BB - HOUSING ASSEMBLY (Clock spring assembly)
5. WPT 404 WIRE ASSEMBLY (Power/ground plug for clock spring assembly)
6. DU2Z 14474 EA - TERMINAL (4 pack of wire terminals with correct end to pin BCM plug - only 1 needed)
Thanks.
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Thanks.
Yep, you got it. To make it easy, I would suggest @JScaro harness to save yourself some time to combine 5 & 6.
GypsyDanger
Jamie
Cleveland, OH, USA
22' XLT
Electrician
For future reference, on a 302A with Lane centering, and if i was okay with just having the soft button on the screen, would this parts list also work?
