FORScan Favorite Mods?
Zengineer
Midwest
2022 Lariat 157wb
I don't get the brighter DRL desire. I set mine to "OFF"
Kodiak
BHunted1
Sumner County TN
BHunted1
Sumner County TN
That's quite a process. Thanks for the info.
If you think you'd like to delve deeper into your truck, maybe buy a cheap windows laptop...
mike4339
mike
CA
2022 F150 XLT
Thanks. I've been planning to buy one for other things as well.
Ttrbe94
Josh
NH
Ford F-150 Powerboost 2022
Double honk disable, BCM
Fog light cornering disable, BCM
DRLs at full brightness, BCM
Enable digital numbers under engine and tranny temp gauges, IPC
Front seatbelt chimes disable, IPC
Door ajar chime disable, IPC
Turn signal lane change tap count to 4, SCCM
Disable windshield anti fogging strategy so recirc stays on, HVAC
Enable front cams with tire tracks in mud/snow mode, IPMA
Glare Free headlights, APIM, IPMA, SCCM, IPC, HCM
Headlamp switch remember position, BCM
Battery target charge state to 95%, BCM
By Battery target charge State do you mean the hybrid? That would be awesome to be able to adjust that!
DK4
Truck
Naw, it’s just the regular battery controlled by the BMS.
