Recent Foscan Mods
fatbassman
Eastern Washington
2022 F150 Lariat 502A 3.5 EB
I had the following done today:
✔Bambi mode
✔Remove "full view not available"
✔Disable double honk when key leaves
✔Numbers on gauges
✔Disable door ajar chime
✔Disable seatbelt chime
All work perfectly. Love it. I had two done with less than optimal results
*️⃣ Power point time out disable.. I had time out turned off. The unexpected result was that the only power point that works when the truck is off is the charging port inside the console. Is that how the mod is supposed to work?
❌ Cameras at speed. My bed camera and rear camera already worked at speed. I was looking for the front camera to be enabled. Didn't work. Any thoughts?
SilverPigeon
Australia
...Cameras at speed. My bed camera and rear camera already worked at speed. I was looking for the front camera to be enabled. Didn't work. Any thoughts?
A s far as I know, the front cam at speed is only for the off-road drive modes.
Yep front camera is speed limited. Ford wants you to look up at the road not at the screen.
Full view not available is the worst information notice ever. It's obvious it isn't the same view as when backing up, it is cropped. They could have put that notice at top or bottom out of the way.
Power point was recently done by someone here towing truck that tested it for several hours. I think that was in Forscan thread few pages back.
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
Yes that was me
It's live 24. 7 now
It's in the forscsn spreadsheet sheet and on the main forscan thread.
stevemcbo
Steve
2023 F150 FX4 Powerboost
✔Bambi mode
✔Numbers on gauges
What was your 4Scan program for Gauge numbers?
fatbassman
fatbassman
Eastern Washington
IPC 720-57-01 xxxx x**x xx--
E5 for turbo with trailer brake
65 for turbo with no trailer brake
25 no turbo no trailer brake
fatbassman
fatbassman
Eastern Washington
Has anyone had any different experiences? Like found a way to get the other power ports (400 watt plug, cigarette lighter, or front USBs to work with the vehicle off? Or found a way to get the front camera or 360 camera at speed? Neither is very important.. just interested.
