Ffdlt371
Diagnostic Trouble CodesDTC's?
What is 90% battery charge?Bambi Mode
Digitalgauges
Global Windows
Added sided screens on Powerboost screen
Silent mode
Glare free lighting
Brighter front marker lights
Bed/hitch camera
Unreal engine
75th anniversary screen
90% battery charge
In regards to the "Enable front cams with tire tracks in mud/snow mode, IPMA",Double honk disable, BCM
Fog light cornering disable, BCM
DRLs at full brightness, BCM
Enable digital numbers under engine and tranny temp gauges, IPC
Front seatbelt chimes disable, IPC
Door ajar chime disable, IPC
Turn signal lane change tap count to 4, SCCM
Disable windshield anti fogging strategy so recirc stays on, HVAC
Glare Free headlights, APIM, IPMA, SCCM, IPC, HCM
Headlamp switch remember position, BCM
Battery target charge state to 95%, BCM
It refers to the max target charge level for the 12 volt batteries. Ford sets it to 80%What is 90% battery charge?
It’s the 2nd mod listed at the very top of the common page on the Forscan spreadsheet.In regards to the "Enable front cams with tire tracks in mud/snow mode, IPMA",
where did you get the forscan change values for this? I can't seem to find it and believe me, I've been looking!
Thanks
that would be a nice featureIs there a way to modify what drive mode the truck starts in with forscan? Say i want it to always start in sport mode and then manually switch to normal or eco.
I did what Robb talks about here and it worked for me.@DK4 How exactly did you do this?
I tried several different code changes posted by others and have not been able to disable this god forsaken "feature".
Thanks. I tried that one before and unfortunately it didn't work on mine.I did what Robb talks about here and it worked for me.
https://www.f150gen14.com/forum/thr...database-spreadsheet.1578/page-44#post-154137
How did you get your turns to stay on with your DRL's?Actually working on brightening DRL's today. Looks like I have to change that in the "as built" section. Just saw what line and code I need to change. I also have my front turns as DRL's with LED bar. Looks sweet!
Already an option in features. Just turn camera delay on.Does anyone know if there is anyway to keep the cameras on when shifting? For example, I hit the camera button on the dash to see how well (or poorly) I navigated into a parking spot. If I have to adjust, the rear camera cubes on automatically while in reverse, but when shifting back into drive I have to hit the button again to activate the Cameras again.
