Forscan - Disable Auto Start/Stop on 2024
GadgetBob
Bob
NY
2024 F150 King Ranch
Military Retired
Just a little more info, does the entire ass/camera assembly slide out? Just the ass button? Don't understand how to plug in the eliminator?
The green piece comes out with the 2 switches as one assembly. There is one plug for both switches that the eliminator goes inline with.
Ford blue blood
Birmingham, AL
2016 Focus, 2018 Lincoln MKZ, 2024 F150 Lariat
Retired, Retired Navy, CWO-4
OK, little more help here. Got the front trim off, can see the top of the assembly and the two "tabs" that hold it in place. How do they hold? Tried lifting one and seeing if the switch would wiggle. Nope, not the first sign on moving. Is there a tool to lift the tabs or does the dash need to come apart to get to the switch?
MGF150
East Texas
2024 F150 XL
I removed the top plate above the radio and was able to unplug the switch from the back and install the in line eliminator from there. Scroll down on the website for the video
Install video
Ford blue blood
Birmingham, AL
That top plate does not expose the back of the switch. The dash cover drops down to meet the top of the radio. There is no way to see the back of the switch. I'm about ready to call it on this....
Ford F-150 Forscan - Disable Auto Start/Stop on 2024 1722790300025-n
Bubbamanlarry
Larry
Kentucky
2024 F-150 King Ranch SCREW 4X4
Construction Company Owner
Guys, I have the same issue. I got Bambi mode and extra turn signal flashes on my new 2024 King Ranch, but Auto Start / Stop isn't working. I'd also love to get rid of the seatbelt reminder chime. Any new news on ASS? Also, has anyone tried the numbers that Hyins posted?
Bubbamanlarry
Larry
Kentucky
Read on another blog that they were able to trick the BMS into keeping the A.s.s. Deactivated.
The computer thinks the little wire has been detached from the battery.
Feature NameModuleAddressValue changeValue changeValue changeNotes
Auto Start/Stop Disable – by disabling BMS (Battery Management System)BCM726-48-02x0xxxxxxxxxx
Auto Start/Stop Disable – by disabling BMS (Battery Management System)FCIM7A7-01-01xxxxx0xxxxxx(optional – disables switch)
Auto Start/Stop Disable – by disabling BMS (Battery Management System)IPC720-01-01xxxx1xxxxxxx(optional – disables stop/start message center in the trip/fuel IPC menu)
Auto Start/Stop Disable – by disabling BMS (excerpt from public FORScan spreadsheet)
Can anyone confirm that this works yet? Thanks!
Perhaps this upcoming weekend I'll get to play with adding a cap to the start/stop switch to see if it's a simple $5 method for disabling it. For those with it as a simple test, before hitting "start" hold down the button, start the truck, and continue holding the button for a TOTAL of 5 seconds to see if the simple cap method will work.
Bubbamanlarry
Larry
Kentucky
I gave that quick fix a try but it didn't work for me. I wonder why the 2024 F150 is taking quite a while to be up to date with Forscan. These guys that work this stuff up do a killer job. I guess I'm as anxious to get a couple more things changed as everybody else.
GadgetBob
Bob
NY
Military Retired
You do not have to get to the back of the actual switch. Use a small flat screwdriver and release the tab at each end of the green piece in your picture. The entire green piece will slide out of the dash and the eliminator plugs into the green piece.
ak49rzrs
Ryan
Alaska
'24 F-150 501A,w/FX4, '18 SHO, '15 F-350 CC/LB 6.7
Liquified fossil recovery
The video fordtruckman2003 posted, Go to 2:17 and watch those few minutes. At 2:20 they show you the back side of the switch and the tab you squeeze and pull the plug out of the switch. Then one side of the harness plugs into the back of the switch, and then the plug you removed goes into the other harness plug of the device. I actually had to edit this. Is your Lariat a special trim level? As I looked at your photo I notice the pleather covering wrapped around and there's a 7 mm screw on the vertical face of the dash behind the front trim you removed. Can you get a picture of you top dash section there? My Lariat didnt have that, just the top pocket which had a lip that slid under the front bezel exactly as the video shows.
reatt
Dan
Central Wa
2024 Ford F150, 2024 Merc GLE 450, 2020 Merc S 560
I installed the 4D tech module on my 2024 Lariat. Simply remove the glovebox and its plug and play. I get a one second message on engine start telling me auto stop start has been disabled. The off light on the upper dash remains on. Neither of those bother me in the least.
Nightshade
AJ
Alberta, Canada
I take it no one has found the FORSCan changes to disable Auto Start/Stop on the MY24 F-150s yet? I know the AS/S changes on the spreadsheet won’t work on the 2024.
Ford blue blood
Birmingham, AL
Put the 4D in yesterday, works perfect!
