Ford Power-Up 6.2.0
mflynndelta
Cary, NC
2021 F150 FX4 Powerboost Platinum White 7.2kw pro
So this 2.7.4 thing is not an isolated case.
yes sir mine failed the update last night
sorry to keep asking but this makes me nervous
do you suggest I let it keep trying to update ?
rugedraw
Javier
Miami
Auto Sales
Yes, let it update. The update has already been installed by another truck and nothing happened. Not sure why Ford would use an old revision number for a new update, but that seems to be what happened. You need to charge up your battery and maybe reset your BMS if you want it to install. It keeps failing for you due to low battery SOC.
https://www.f150gen14.com/forum/thr...read-f-150-lightning-mach-e.16968/post-397458
Spiffers
Craig
Tennessee
2023 Lariat
I just bought my 2023 today and it alerted me that it updated to 6.2.0 today.
FirstTimeFord
2023 Platinum here. Excuse me if I presenting facts already discussed. I've received 6.2 twice now as shown in the photos. I've towed a trailer twice recently. The earlier tow, I noticed in my camera views the option for just side mirror cameras, like a split view that would be great for turn signal activation. Wish I would have grabbed a photo because now that view is gone, while towing or not. The second time towing, more recent, I was using Android Auto Google maps for nav. Maybe it's always been like this but as shown in the photo, I noticed my lane keep minimized under the speedometer. Has it always been like this or is this part of the update? Hope I can get those side cams back. More is better on camera options!
Side note, the updated colors for Google Maps is big miss for me. The blue lines for your route and alternate routes are very confusing. Try again Google.
Ford F-150 Ford Power-Up 6.2.0 20231203_170257~2
Ford F-150 Ford Power-Up 6.2.0 Screenshot_20231203_112920_FordPass
Your driver assistance under the speedometer is perfectly normal.
It will only be in the center of screen if you have that view turned on.
Play with your screen you have many views to choose from. I usually just keep it on fuel mileage but switch to power distribution when I'm running 4A sport mode.
Not sure what you mean about cameras. Since you have a 23 you might be able to get super duty turn signal cameras to work, many changes to make in Forscan and I can't tell you what they are at moment. Post on Forscan thread asking about it if you want to try it.
FirstTimeFord
Makes sense, I usually have lane keep in the center. Was in calm I guess and never noticed. I've never applied any Forscan changes. It seems like the split screen cams were there for the short time they sent the original 6.2. I've only seen it that one time. Will post back if I see them again.
tntlars
Todd
Iowa
22 ST Explorer, 22 F150 Lariat
Interesting, I had the same problem and also thought my cable wasn’t seating properly or something.
The other issue I’m having since the update is Ford Pass is reporting my truck’s location as Dearborn, MI.
[/QUOTE
Anyone get an update so you see correct address of truck on fordpass?
I just got 6.2.0 second round and still shows truck in Dearborn, MI
FirstTimeFord
Mine shows current address. Updates by current location. On 6.2 (v2)
tntlars
Todd
Iowa
I was told by Fordpass support that it was a known issue after 6.2 (v1) that it affected address in fordpass for some trucks always showing in Dearborn MI and they were working on it. Then I recieved a call 2 weeks ago saying that the fix was ready and that it would update it the next 2 weeks, well it updated tonight to 6.2 (v2) and it still shows truck in Dearborn, MI.
Rineland
New York
2022 Ford F-150 XLT 302A 4x4 CCSB 3.5L EB
I just received 6.2.0 (v2) today and it’s still reporting Dearborn, MI as its location in the Ford Pass app.
tbinmd
22 KR F150
Google updated maps app recently and changed the color scheme.
redline
Calgary
2025 f150, BMW M3,VW Atlas
I got the update update 6.2.0 revision yesterday morning and it was weird, i am not sure if it related or just a weird event … the rear diff locked like it was in 4L and changing for 2H to 4a or 4h did nothing thing… i finally put the truck into eco mode and that fixed it and now back into normal mode and the truck is fine again…
