Possibly 6.4.0? ?
Not sure why the door modules are still there.. i updated them the other night.. as for the acm its says its only to add sub when i try to update.. the ipc says its 3 hours.. just don't want to go that long on a update.. and the abs just made the list the morning because i did not see it last night.PTS does show 6.2.0 installed successfully on 10/31. What's interesting is that IPC update that is showing for you in the list @C. Mays provided.
Thanks for looking into that Rugedraw... now i have to figure out why my truck keeps telling me its going to update when it all ready did.PTS does show 6.2.0 installed successfully on 10/31. What's interesting is that IPC update that is showing for you in the list @C. Mays provided.
mine is all most every day to every other day.. was there last night ..not there this morningI’ve had that happen twice now. It seems to come by every 5-7 days.
A few people have reported the ABS/DDM/PDM updates not coming off the list after doing them with FDRS. They'll come off eventually.Thanks for looking into that Rugedraw... now i have to figure out why my truck keeps telling me its going to update when it all ready did.
I would ask @rugedraw to check your vin and see what's going on, most likely if you're past 2.7.4, which you should be. The update will fail to install. Probably a good thing.I got 6.2.0 a few weeks ago
now I have notification an update is waiting for tonight and it is 2.7.4
what should I do ???????
Very strange. It says 2.7.4, but that's an old IPC update. This is showing as a very small BCM update.
Should I try to stop the update ?Very strange. It says 2.7.4, but that's an old IPC update. This is showing as a very small BCM update.
Honestly, I'm stumped. Idk wtf to make out of this. Lol
Somewhere about a year ago my truck kept attempting the 2.x IPC update, Jesse actually looked at it and found a file mis match. There were 2 files 1 had updated but the other didn't. He had to remote into my truck and installed the file with forscan. Since then IPC updates have installed without problem. But without his help my truck would have been in an endless ota loop trying to install that 2.x update. You may want to ask Jesse to check your configuration.Very strange. It says 2.7.4, but that's an old IPC update. This is showing as a very small BCM update.
@Jesse-Infotainment Can you please take a look ?Somewhere about a year ago my truck kept attempting the 2.x IPC update, Jesse actually looked at it and found a file mis match. There were 2 files 1 had updated but the other didn't. He had to remote into my truck and installed the file with forscan. Since then IPC updates have installed without problem. But without his help my truck would have been in an endless ota loop trying to install that 2.x update. You may want to ask Jesse to check your configuration.
