Ford Performance Diff Cover
nkyhunter
mark
nky
2024 Mustang gt/cs pp, 2022 f150 tremor
I have 3.55's e Locker with tow package (not max) and have the 9.75 rear end. I got FRPP Cover. it's 12 pounds of iron vs the thin stamped steel and will absorb a lot more heat. Also if you manage to backup and hit something the iron is way more durable. I changed mine rear cover and oil (used AMSOIL 75-110) out with about 2k miles, there was a very fine black particulate in the pumpkin. Use blue shop towels to wipe out inside the pumpkin. When gears first break in from the factory there is acids and metal that get released from the gear set. I was not going to leave it in... Cover also has magnet drain plug to keep the metal out of the oil/gears. If you are going to do it get the LUBE LOCKER gasket! Really nice and they do not leak.
More durable, absorbs more heat, has magnet, makes change easy, wont rust like cheap stamped steel. No way I was going to wear 'dirty underwear' for the first 80k miles of life.
My picture I took!
In the end I got this one and now deciding on what gear oil to use, weight 75-90
SALEEN961
Radnor, PA
2021 F150 XLT 302A
Automotive Technician
Ford recommends 75W85 gear oil for our trucks, but they used to recommend 75W140 for the 9.75" and I still prefer using that viscosity for severe use. I normally use Redline 75W140NS and add Ford XL-3 friction modifier, but Redline's standard GL-5 gear oil that already contains friction modifiers is a good option for most people.
tony72cutlass's'
Tony
Halifax
But only if you have a limited slip like yours right? Not for e-locker but I could be wrong
SALEEN961
Radnor, PA
2021 F150 XLT 302A
Most synthetic gear oils already have friction modifiers added them, and they should all be safe for use with an e-locker or open differential. It can be difficult to find a synthetic gear oil without added friction modifiers in many brick and mortar stores.
Many synthetic gear oils will advertise that no additional friction modifiers need to be added for use with limited slip differentials; but I have had bad experiences in the past, and I prefer to buy gear oil without added friction modifiers so that I can add it myself. Adding it myself gives me control over how much is added, and I don't have to worry about the additive not working well with my clutch packs.
I'll also like to add a bottle of Ford's XL-3 friction modifier to differentials that don't require it after installing a new set of gears because it helps to reduce gear temperatures. In my mind it's just cheap insurance, and I know that some customers aren't going to take it easy while the gears break-in during the first 500 miles like they're supposed to.
tony72cutlass's'
Tony
Halifax
very interesting, I didn’t know they added it into most synthetic oils.
i watched a guy take apart an e-locker on YouTube it’s a pretty simple/cool design.
Babbage
Upstate, NY
2021 F150 3.5 XLT 302A FX4 PP2K 36GAL TOW
Wild horse rider
ok so here are my thoughts on this:
Ford recommends SAE 75W-140 PREMIUM SYNTHETIC HYPOID GEAR LUBRICANT, with XL-3 Friction modifier.
https://www.motorcraft.com/us/en_us...e-75w-140-synthetic-rear-axle-lubricants.html
It has enhanced wear protection for hypoid gears, excellent shear stability and protects from rust and corrosion. This product meets all fill-for-life requirements of Ford Motor Company.
Note: For a complete drain and refill, some limited-slip axles require addition of Friction Modifier, Part Number XL-3 meeting Ford specification EST-M2C118-A. Refer to Workshop Manual or Owner’s Guide.
(in the link for Motorcraft 75W-85 it states:) Do not use in axles here SAE 75W-140 is recommended.
Motorcraft XY-75W140-KL (75w-140 hypoid gear oil) is about $30 a quart and you need 3 (about 2.5) to change it out. Amsoil was less and has the FM in it.
I went with Amsoil 75w-110 severe gear as I wanted a touch thinner for mileage and power, and also I now have a 12lb iron rear diff cover -- it would absorb a lot more heat than the thin stamped steel cover ever could.
Also Amsoil works for Hypoid gears: https://blog.amsoil.com/what-is-hypoid-gear-oil-and-other-gear-oil-questions-answered/
I do not currently 'torture tow' heavy loads through the mountains, campers etc, if I did I'd go Motorcraft XY-75W140-KL with XL-3 - with the Ford Racing cover, (and lube locker gasket!)
Manual says to use the 75-85 though.
I still have 75-140 from my Gen 12 truck.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
I know this is old, however, I just wanted to make note. The bolts that come with the cover, they are garbage! Don’t try to use them throw them away. I torqued to 14 lbs ft with a snap on torque wrench with recent calibration.
When I installed them, I snugged all bolts with a ratchet. When torqued, most bolts went about a quarter turn & click. One of the bolts got to about that same point and then I got almost another quarter turn. I was just getting ready to stop & it snapped.
Luckily there was about 1/8” protruding from the housing. I was able to get it out without pulling the cover.
Ford F-150 Ford Performance Diff Cover IMG_4844
Babbage
Upstate, NY
Wild horse rider
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
For those of you who did this upgrade. How did you get the top bolts off/on....the spare tire carrier seems to be the in way.
Jack the truck up. Jack stands under the frame. Let the axle sag, creates quite a bit of room, enough to where I could remove the hardware with my Dewalt impact
amschind
Adam
'21 F150 SCrew 4x4 Powerboost
Physician
1) get it
2) Its ludicrous that the stock front and rear drain covers do not have drain and fill plugs.
3) I used mine the other day. I THOUGHT that the lid for a partly used container of hydraulic fluid in my truck bed was securely fastened. I arrive home after a long drive to find the rear passenger tire covered in oil. I have to drive across Texas for work in 2 days, and rental cars aren't cheap. I immediately drive to my mechanic whose shop is down the street, but before I do, I check the diff fluid level expecting it to be empty based upon the oil tsunami. I find that it is full. Drive a few blocks and deduce the rest of the way that it's not brake fluid either, and then find that I have about $80 of Kubuta SUDT2 fluid smeared all over my truck's undercarriage.
The point being, it is very useful to be able to check fluid levels.
amschind
Adam
Physician
I did the Spicer cover . Used the lube locker gasket and re used the original bolts. They are tight on there for sure
The Ford cover is the Spicer cover with a Ford logo riveted on it.
