Goldeneye36
A few days ago I changed my oil and reset the OLM. It seems to be working properly so far but I'm eagerly awaiting my monitor to start freaking out like everyone here has been describing.
Do you HAVE to take it in for this? Cant update overnight in the driveway?Back from Ford today. They did a software update for the oil life indicator. Apparently there is now a technical service bulletin for it now. So far, so good. We shall see.
Good news is even though they updated a bunch of modules, my ForScan changes seem to remain intact.
I am looking forward to not having to dismiss that message every time I start my truck!
This was a service update, and for me it had to be at the dealership. I don't have the TSB # in front of me right now. I know they updated a bunch of modules. It took several hours, so probably not something they can roll out over the air.Do you HAVE to take it in for this? Cant update overnight in the driveway?
Pain in the arse for something that should have been proof tested before selling the vehicle. (Putting them on the lot)This was a service update, and for me it had to be at the dealership. I don't have the TSB # in front of me right now. I know they updated a bunch of modules. It took several hours, so probably not something they can roll out over the air.
This is not about "a bit too short". For people that have the bug like me, it asks for an oil change after a stroll around the block. The other day it reset even without a drive, I just reset, turned it off, turned it back on, and it asked for an oil change.I believe all the oil life monitor is doing is monitoring engine RPM, engine temp, idle time, along with driving conditions (i.e. towing or not) and total time elapsed to come up with a rough estimate of oil life. For example if you do a lot of short trips in cold weather it will drop faster, but if you do long steady highway driving, it will last longer. With that said, if you DO have to reset it, either a quarter or half way into its oil life, now the 100% rating is off, so you have to use your own judgement/testing of the oil manually to ensure its good. I've always been old school for these very reasons. I'd rather know, than depend on a gadget.
Right. Clearly an annoying bug. But because of crap like this potentially happening, I always tend to not trust what a gauge tells me and do it the old school way. Perfect example is the TPMS. I have never trusted that pile of trash. Always check my tires manually with a calibrated tire pressure gauge. You do have to be somewhat careful with trusting that a tool can do everything or is 100% accurate, for example those brake fluid testers. They are hit or miss based on what composition the manufacturer used to create the fluid, otherwise a boiling point tester is required. But you know what's easier than that? Just simply knowing when you are supposed to change it. As far as physical brake pads are concerned, you will know when the pedal goes to the floor. Simple. No tool required. The problem you are experiencing is exactly why I'm anti-technology to a degree. I hate it with a passion. But we are stuck with it, so no choice but to learn it I guess.This is not about "a bit too short". For people that have the bug like me, it asks for an oil change after a stroll around the block. The other day it reset even without a drive, I just reset, turned it off, turned it back on, and it asked for an oil change.
