Jmitchelltfo
Running two Audison amps with 1/0 wiring will probably be taxing on the factory battery. I was hoping to run an upgraded battery and had already considered the H8 option when my H7 needs to be replaced. I will also be replacing my aux battery and live in the Ozarks, so we don't have frigid temps very often (had maybe 30 days below 32 F last winter).Try manually resetting the BMS. The truck does track the age of the battery as a variable and the manual reset procedure makes it think it got a new batt and changes its behavior. No reason a 12.7+ voltage should be triggering a service charging system.
I bought another battery tray off ebay for $50 delivered as it was unknown territory cutting into the tray itself to make that fit. LFP battery life can degrade quickly if charged below freezing which is why I've not really suggested people to go LFP aux route due to the varied winter conditions seen across the US. That battery is touching the lid -- its fit is tight, but the lid closes / snaps in. if it was 1/8th inch taller it wouldn't close.
You could use an H8 if you pull the battery isolator out of the battery tray and just leave it chilling next to the battery under hood. The wires are sufficiently stiff to keep it in-place. Wouldn't be hard to secure it if desired -- I didn't try. The LFP affords me a 'free' 25ah worth of reserve capacity before the under hood AGM starts to get consumed which is quite considerable. Can't speak to the long-term effects of this arrangement though. Keeping the AGM at 100% is supposed to have long-term negative effects but I'm not sure when they'll show up. It's only used for starting the ICE while moving in hybrid mode so even if it degrades to 70% health it still might not show up.
TL;DR I'd just like to run a reliable auxiliary battery that has some increased aH capacity. I don't really care if it is lithium or AGM, I just want it to last several years and be as reliable as possible. If that costs a couple extra bucks and takes a little bit of modification to fit, I'm ok with it.
