sswalters
Georgia
2021 F150 King Ranch
Exactly as @SilverPigeon says you can do the bcmc, and attemp the bcm.
Ford F-150 ECU module programming guide using FDRS imag
Ok done!!!
I’ve run the Audio Front Control Module four times and it installs correctly yet still shows up. So will ignore that now.
Also the BCM update still shows the logins. So I cancelled.
But look at this screen of beauty!! What a relief!!
(hopefully the Parl Assist Fault and 911 calling thing resolve.)
sswalters
Georgia
Took it for a spin. Wow the audio updates really get those ceiling speakers and headrest speakers working great.
As soon as I unplugged the mongoose and took it for a spin, I didn’t get any parking assist or 911 calling faults! Hopefully all is well with the world again.
Next up is Forscan and BC 1.4!
Love you guys. Sorry to blow up your feed today. I’m on this thread for life now.
Have a great sleep!
RickBullotta
Rick
Pennsylvania
2021 F-150 Lariat Powerboost
Have a great sleep!
Now try playing some Apple Spatial Audio - even with my "base" Bose system it sounds great now.
Big Dog Daddy
New Jersey
Have a great sleep!
Well done! Sir, You have a new truck now and you made it happen. :)
TBeatle
Michael B
MN
2021 F150 Platinum
@rugedraw - interesting thing, started the car yesterday evening and the unreal theme is gone. I double checked APIM changes I made and all are in line with livn's sheet. No new cameras at speed and now unreal theme and climate bar dont show on bottom of screen.
I cleared the PCM DTC and ran the configuration from the TSB and errors are cleared. Thank you!
One new issues has presented, hoping someone might have suggestion. Running boards make loud whinning (running motor) noise for 3-4 seconds after running boards have been deployed. I ran the self test, no issues and didnt make the noise. Seems like module needs to relearn where down is. Thoughts?
My running boards started doing that also after one of the last updates.
MPP1234
MP
NH
I tried doing self test of driver seat module and it doesn't do it during the test and does it sporadically but almost always when going down only now.
MPP1234
MP
NH
Hi @rugedraw - So oddly enough PSCM module sometimes comes back with No Response and grey in DTC section of FDRS. Also SACM and SECM are throwing errors intermittently. I have rebooked GWM and APIM several times. The PCM module has thrown that U031D code several times and I've had to run the disable program a few times as well.
I've gone through 2 2-day licenses now and feels like a bit of a loop. I was going to pay for one more go to try to calibrate the IPMA cameras as you suggest. Any other suggestions? Shld I do something to reset the IMPA or APIM back to factory (especially because the edits for cameras is not working and unreal theme disappeared despite being setup per the sheet)?
It seems like there may be something going on here that goes beyond my scope of knowledge. As much as I try to deflect as much as I can from him, it may be a good idea to PM Jesse with your VIN and concern to see if he has any ideas.
You can calibrate the IPMA with FORScan. You don't need FDRS for that.
MPP1234
MP
NH
Thanks @rugedraw - Really appreciate everything... despite the errors the truck is like a brand new truck with all the improvments.
nkyhunter
mark
nky
2024 Mustang gt/cs pp, 2022 f150 tremor
Any chance the IPMA update showed up for you?
havent logged into FDRS in awhile, not sure I still have the BCM to get updated, still need to make appointment at dealership to get that done then maybe it might?
Big Dog Daddy
New Jersey
Correct, The BCM still cannot be updated with a non dealer login to FDRS.
FI300
Rex
Alabama
2021 F-150
The IPMA update is not dependent on the BCM update that requires a separate dealer login.
shaikhasm
Ahmed
Saudi Arabia
2023 F150 Raptor
Hi
When trying to update the apim, I keep getting this usb error. I formatted and reloaded the software on the flash drive but still get the same error.
1FTFW1RG5PFB73809
Ford F-150 ECU module programming guide using FDRS IMG_5578
farmtruckman
Dubai
2021 F150 Raptor
Hi
1FTFW1RG5PFB73809
Are you logged in through a VPN? What is your current Sync version please? What is the size of the APIM update?
farmtruckman
Dubai
2021 F150 Raptor
Has anyone received the anticipated APIM update(s) Ford said they will release in October 2024?
