speedracercjr
Cory
2021 Lariat EB
O&G
So is it go time to get a license for FDRS and get BC1.4? Or are we still waiting for a few more modules?
OleMustyBag
Spring, TX
2023 F150 XLT 5.0, 2015 GMC Acadia, 1963 ChevyNova
Having trouble updating IPC module. It is a Raptor IPC in an xlt that I swapped out. Everything works on the cluster accept auto headlights and glare free. I was trying to update it to eliminate that possible problem with the headlights but it fails every time. I am running FDRS 38.5.7 and have successfully updated many other modules. See pics for error codes. Anyone know why this could be happening?
Ford F-150 ECU module programming guide using FDRS IMG_9210
Ford F-150 ECU module programming guide using FDRS IMG_9209
nitrobass24
Website
redboxplus.com
'21 F150 Platinum PB
Roll offs and Porta-Potties
Will not work. Doesnt work that way.
OleMustyBag
Spring, TX
Could you elaborate please? Will not work because it is a Raptor cluster? Is this because there are Raptor modules missing like the VDM? Or is it because of the VIN? Could this Raptor IPC be causing my glarefree to not work? Thank you for your expertise on this!
Its a VIN issue your truck doesnt show that cluster as a Part number. SO it will fail. It doesnt look at the part and pull the files it looks at the vin and compares the part and if it doesnt match it fails it.
OleMustyBag
Spring, TX
So even after performing the write VIN procedure with FDRS it still will not accept that as a valid part? Is there a way to make it accept that IPC?
Vin doesnt get written to the IPC. No. You dont want that part number to be associated with your truck.
The only thing youll do by putting a Raptor cluster in is F up your future updates.
These newer trucks are nothing like the older ones. One module with software that isnt correct will block all updates. So even if the Cluster part number get absorbed on Fords end it will absolutely screw your other updates because they are sequenced and stacked.
Sounds like sell off the Raptor IPC and buy the correct one from somewhere like the place Jesse works. ?‍♂
Some confusion on the recent BCM update. Is it causing issues for turning headlights or the lower trim lights?
I'll have to use FDRS to get the IPC done so might as well do whatever else is there at the time. I don't want to break my lights or anything else with a bad update.
I cant say for sure BUT two people I know did it with no issues. They have the highest trim lights
OleMustyBag
Spring, TX
Ok good to know!
Would a digital cluster from a lariat cause the same problem? Or just the Raptor?
ok thanks!
That sucks because it looks really awesome
Ok good to know!
ok thanks!
Once you venture into the arena of hardware customization that you appear to have done, you would need to be able to control your own destiny regarding module software/firmware upgrades. Sometimes down to the individual file level.
You have every right to do so, and I even celebrate those that do so. But it's not for the feint of heart! ?
I personally would only do so if I were also willing to establish a business relationship (good Ole commerce $) with one of the few people that can navigate such waters with the knowledge prowess necessary.
I don't face such challenges since I purchased a trim level at the very top of the software chain, but I have to admit that I'd be intrigued with the challenge to modify an XL into EXACTLY the truck Ford wouldn't build, if you know what I mean. :)
OleMustyBag
Spring, TX
Yes I agree
I have gotten in deep!
I am new to the forum thing and it has been a great help and wealth of knowledge!
I bought a high trim XLT and added Raptor projector headlights (because I wanted amber DRL) with HCM and did a Raptor cluster swap ( did not realize Raptor cluster was different at the time) added rain sensor, katzkin leather seats etc. It has been fun, however next time I will just buy a platinum and call it done lol.
