iceman77
Pete
2022 Ford F-150 Platinum
No, the latest is 22028 Rev 358 which is what mine updated to this morning.
Any noticeable changes in Sync ? Did they fix the ACC SSR ? How is CarPlay screen look like ? I had a full list of bugs reported to them.
abd79
Wayne
2025 F-150 Raptor
For the smarter guys in here, I was able to pull logs from the nano itself, wireshark works as well but includes all the USB overhead so I'm trying to filter it out and see if there is anything of use. I'm suspecting that the problem maybe timeouts/buffering in the nano that needs to be tweaked. could be wrong but its a start unless you already had this. May be useful in talks with AllScanner guys. I should also note this log is of a offline network scan
OTA or FDRS?
I hope this recent turn in the thread doesn't scare folks off too much. Just when there was amazing momentum to addressing trucks that were far behind in updates, suddenly it feels like the updating wasn't worth the risk.
Maybe I SHOULD be more worried but I can't find anything malfunctioning on my truck and I've done all the "scary" updates. Lol
And I haven't even figured out how to go check and see if my cloud is "corrupted".
I guess I need to go back and re-read the posts that I wasn't paying close enough attention to.
iceman77
Pete
OTA or FDRS?
I will check your AB data in cloud tomorrow morning and let you know!
Well that's mighty nice of you kind sir.
So if it is, I thought it was established that in the long run it wasn't an issue since the truck itself would.... I think it was described "talk to the mother ship" and overwrite anything FDRS might have uploaded less than perfectly. Afterall, the truck is the final say.
By the way, I could buy another license for doing it myself, but I really appreciate you sparing the expense. I swear I should just purchase the annual subscription and be done with it. Lol
TJSparky
WA
Iceman- if you could check my cloud data too I’d appreciate it. PM sent
Darkjeep
Dan
Hastings, MN
F150, CR-V
God of Tech
I have been comparing my first AB data to the most recent. That stuff is weird. I think when I tried to fix the lost radio tuner and out the original AB from July I was almost able to apply the 1.7.1 APIM usb from FDRS. It at least saw the data on the drive. Then I screwed up everything.
antho
Anthony
Houston, Texas
2024 Raptor 37
Just flipping through. For example. This transfer contains 34 messages.
[19:48:29.115] PassThruReadMsgs.
[19:48:29.115] ulChannelID = 1
[19:48:29.115] pstructJ2534Msg = 0x43e6c7a8
[19:48:29.115] *pulNumMsgs = 100
[19:48:29.115] ulTimeout = 50
[19:48:29.115] ulTimeoutReal = 50
[19:48:29.176] RX Msg Timeout. rxMsgs = 34
[19:48:29.177] *pulNumMsgs = 34
[19:48:29.177] Msg Num = 34
Message 0 looks good.
[19:48:29.177] Msg #0 :
[19:48:29.177] Msg->ulProtocolID: 0x00000006
[19:48:29.177] Msg->ulRxStatus: 0x00000009
[19:48:29.177] RXSTATUS_TX_MSG_TYPE
[19:48:29.177] RXSTATUS_TX_INDICATION
[19:48:29.177] Msg->ulTxFlags: 0x00000040
[19:48:29.177] TXFLAG_ISO15765_FRAME_PAD
[19:48:29.177] Msg->ulTimeStamp: 2965564453
[19:48:29.177] Msg->ulDataSize: 4
[19:48:29.177] Msg->ulExtraDataIndex: 0
[19:48:29.178] Msg->ucData: 00 00 07 26
Message 5 looks bad See the highlighted in red. This is what im thinking is corrupting the Hex.
When i remove the Hex in red, The remaining Hex converts to ML3A-7H417-GE
[19:48:29.182] Msg #5 :
[19:48:29.182] Msg->ulProtocolID: 0x00000006
[19:48:29.182] Msg->ulRxStatus: 0x00000000
[19:48:29.182] Msg->ulTxFlags: 0x00000000
[19:48:29.182] Msg->ulTimeStamp: 2965615346
[19:48:29.182] Msg->ulDataSize: 31
[19:48:29.182] Msg->ulExtraDataIndex: 31
[19:48:29.182] Msg->ucData: 00 00 07 69 62 f1 13 4d 4c 33 41 2d 37 48 34 31 37 2d 47 45 00 00 00 00 00 00 00 00 00 00 00
00 00 07 69 62 f1 13 = ???
4d 4c 33 41 2d 37 48 34 31 37 2d 47 45 00 00 00 00 00 00 00 00 00 00 00 = ML3A-7H417-GE
antho
Anthony
Houston, Texas
2024 Raptor 37
Msg->ucData:
00 00 06 f8 62 f1 13 4d 4c 33 54 2d 31 34 44 30 36 38 2d 45 48 00 00 00 00 00 00 00 00 00 00
Removing the above in red makes the HEX = as shown below. Not sure what these extra values are.
4d 4c 33 54 2d 31 34 44 30 36 38 2d 45 48 00 00 00 00 00 00 00 00 00 00 = ML3T-14D068-EH
abd79
Wayne
2025 F-150 Raptor
I’ve fired off support messages to both the hardware and software vendors. I’ll see what they come back with if anything and PM you.
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
I need to look deeper and I'll post some images. FYI, I have Android Auto...
