Paul Neubauer
Paul
I am curious what it would require and cost for us to fix this horrible IPC issue.
rugedraw
Javier
Miami
Auto Sales
A lot more than a Mongoose and FDRS license....that's for sure. You can get a used one on ebay for $500, but you'd still need a Mongoose and FDRS to program it. Hopefully, it doesn't have the same problem. A new one through the dealer would be a few grand with labor and programming.
When it drops for my truck, I'll CAN that b*itch in on a Sunday while I watch football and consume alcoholic beverages.
Paul Neubauer
Paul
It seems like you are leaving too many opportunities for something to go wrong with the process that takes that long to complete compared to a quick USB update. I have no choice but the CAN option and not paying that kind of money to fix it.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
For those with the IPC problem, is there any chance that it's as simple as a loose/unplugged wire or cable somewhere? I'm not familiar with the connections to/from the IPC or where they may go back to.
rugedraw
Javier
Miami
Auto Sales
If I remember correctly when I spoke to @Jesse-Infotainment about this a while back, he said that he's had IPCs on his workbench that he was not able to communicate via the ethernet port. Is it possible that some of the trucks affected have a loose connection? I would have to say it is possible.
Paul Neubauer
Paul
Now I'm curious.. where is this module located to check connections?
rugedraw
Javier
Miami
Auto Sales
The IPC is your instrument panel cluster. You'd have to pull it out of your dashboard to check the connections.
Jesse-Infotainment
Jesse
2024 F150 Lightning
Its the cluster.
Issue I have seen personally is the ethernet port doesnt work on some clusters. I have had a few clusters I have attempted to update via USB not work. The ether net is used to update the Cluster. Thankfully the ethernet isnt needed for BC to work. The IPMA ethernet is required for BC to work.
So if you have an IPC that had constant IPC ota fails then it may be due to the ethernet not working.
No real good way to explain to the dealer you need a new cluster because the ethernet isnt working.
I wouldnt want my cluster replaced anyways. Dealers have goofed up several of the guys that had them replaced by not inputting the mileage correctly and the Engine Hours.
New BCM showing for the truck today
RickBullotta
Rick
Pennsylvania
2021 F-150 Lariat Powerboost
Its the cluster.
here's a question - what if the latest IPC update is to fix something related to this?
Yeah, I don't have any issues that need BCM attention. Won't install it anytime soon.
JEB
US
2021 F150 Lariat PB 502a
Might be related to TSB 23-2407, which just came out a couple of days ago. If it is, expect a new PCM update to follow:
Issue: Some 2021-2022 F-150 vehicles equipped with a direct current/alternating current converter module A (DCACA) inverter (minor feature code HUKAK) may exhibit a Pro Power Onboard Unavailable message in the vehicle center display screen with DTC B15DA:09 in the BCM. This may be due to the software level of the BCM and powertrain control module (PCM). To confirm a vehicle is built with a certain minor feature code, review the build information by double-clicking the vehicle identification number (VIN) in the upper left corner in the Professional Technician System (PTS). To correct this condition, perform the Service Procedure below to reprogram the BCM and PCM to the latest software level via the Ford Diagnosis and Repair System (FDRS).
Jesse-Infotainment
Jesse
2024 F150 Lightning
It wont fix it until its installed so they would still have to go the long route.
