speedracercjr
Thanks!! Looks like I’m re-upping FDRS as I don’t think the truck is going to fix itselfI’ll look as soon as I get home and see. It’s nuts because I’m concerned your as built reverted also.
Don’t yet. I can possibly send you the files to put on a usbThanks!! Looks like I’m re-upping FDRS as I don’t think the truck is going to fix itself
10-4, I’m out and about for the next couple of hours so it’ll be a while anywaysDon’t yet. I can possibly send you the files to put on a usb
Not only did it install an old version on your APIM it did on your TCU. So Ill look at what files I can get right now.10-4, I’m out and about for the next couple of hours so it’ll be a while anyways
What the flying fuck Ford. Looks like auto updates are off for life now.Not only did it install an old version on your APIM it did on your TCU. So Ill look at what files I can get right now.
EDIT - TCU is fine. It actually updated it to the correct level. DJ. I dont see why or what happened to the OTA for the APIM I have no idea as to why it reverted to the level it did.
Only thing I can think is since you were one that had the failed OTA and blanked out version they sent it out. I think its stupid how ford does the Updates sequentially. It make zero sense. If htere is an update wouldnt the latest update hold all the latest info? WHo knows but all you need to do it install the update for the APIM again. THe config thankfully didnt change from what I can see.
Ill send you a link for the files to load onto a USB here in a few.
Yeah.. This is an eye opener for me. Ill be disabling mine. You had received a Gateway update on the 24th of May. IT was correct.What the flying fuck Ford. Looks like auto updates are off for life now.
thanks as always @Jesse-Infotainment
And that makes sense, that’s when I got 2.8.2 pushed OTA to me.Y
