Jesse-Infotainment
Jesse
2024 F150 Lightning
How would someone go about updating Sync 4 with internet explorer? This message appears in the Sync section in PTS when looking at a current gen VIN. Can we update Sync 4 manually without FRDS?
You cant update Sync 4 in Explorer. Explorer was used for MyFord Touch and Sync 3. Explorer was supposed to die in June so Ford moved all Sync programming to FDRS including MFT. Sync 4 has to be done in FDRS.
Jesse-Infotainment
Jesse
2024 F150 Lightning
Any Idea why it skipped 2.7.2? Everything I read people have gotten these latest OTA's in order.
I believe 2.7.2 is Power Boost Only and you are a powerboost. I just looked. SO you should have gotten it.
Jesse-Infotainment
Jesse
2024 F150 Lightning
I guess this is where I sigh with relief that Ford hasn't even hinted at cranking up OTA for 2022 trucks. Or certainly not Job2
In fact, their mission is to catch all F150's up to what the "current current" is, which is that Job2 2022? :)
You have an IPMA update available..
Jesse-Infotainment
Jesse
2024 F150 Lightning
Hopefully mine was just a fluke and it doesn't become a wider problem. But like I was telling Jesse I don't know if the dealer would even know what to do with it and who knows how long it would take. It nuked my whole system, no audio, no maps and lots of messed up visuals.
Is your Screen ok now?
Jesse-Infotainment
Jesse
2024 F150 Lightning
I have a strong suspicion what is going on.
I had the exact same thing occur and so did someone else on the other F150 forums. 2.7.3 is an IPC update. After this update installs the IPC attempts to rewrite its as built and fails. The GWM sees a successful update to the target node and reports it as such locally which we see on the APIM as a pop up, but because of the failed end stage we get stuck with a U-2100 code and failed update error reported back to the server side.
The persistent DTC created by OTA 2.7.3 then blocks OTA 2.7.4 which is a sequential IPC update. Because OTA 2.7.4 cannot proceed owners are getting stuck until the persistent DTC is cleared.
This fault can be cleared with ForScan by force rewriting the all current as built data or with FRDS via a Recovery PMI process which force rewrites all known as built data. I posted about this a few pages ago in greater detail (link below). I think this error only occurs to owners which have previously made edits to their as built, but it could be that OTA 2.7.3 is corrupting random IPCs.
I have not checked your DTC's, but I'm willing to be you have U-2100 set in the IPC.
Here is my solution:
https://www.f150gen14.com/forum/thr...ng-guide-using-fdrs.8249/page-354#post-232391
He doenst. It flat out failed.
Jesse-Infotainment
Jesse
2024 F150 Lightning
speedracercjr
Cory
2021 Lariat EB
O&G
Now I'm wondering if there's a way to disable auto-updates at a deeper level than just in Sync.
Yea, I had a little birdie (Iceman) tell me about it a couple of days ago and I hit FDRS up to confirm. At the time it wasn't listed.
I'll go take another look. Thanks Jesse :)
I'm tempted to just leave the truck be though for a couple of reasons.
1. It's so perfect! I know this one is only a couple of months old and still low mileage (2500). But it's just so flawless. Spectacular. No glitches of any kind and even the drivetrain is smooth and the OAR stays pegged at -1 and it rarely ever pulls timing (KR) regardless of the dreadful oem shift strategy.
2. I'm curious if/when Ford will make its first attempt to OTA the truck. Surprisingly Ford hasn't tried to OTA the TRM update that was queued up before the truck even left the factory. So if there's now a second update (IPMA), maybe I might get some OTA action? Lol
Jesse-Infotainment
Jesse
2024 F150 Lightning
2. I'm curious if/when Ford will make its first attempt to OTA the truck. Surprisingly Ford hasn't tried to OTA the TRM update that was queued up before the truck even left the factory. So if there's now a second update (IPC), maybe I might get some OTA action? Lol
I understand completely. I hate doing anything involving the IPMA> Its a 3 hours ordeal.
speedracercjr
Cory
2021 Lariat EB
O&G
That was the main reason I had OTA's on for auto update, I was hoping to get the TRM via OTA as well so it would clear the stupid recall notice. Obviously that didn't work out so I'll just update it manually and have the dealer clear the notice next time I'm at the shop.
By the way, just to prepare for a possible OTA, I fetched the truck out of the barn and parked it on the RV porch on a charger. It was at 12.3 and I'd like to see it up at 12.6 or better just in case.
However, I checked FDRS @Jesse-Infotainment and I still don't see an IPMA for the truck. :)
But maybe I can trigger that TRM BB update to go. Who knows. :)
Ford F-150 ECU module programming guide using FDRS 20220704_100455
Mike G
N. AL, USA
I have the same charger PL2320...as well as the PL6100.
I usually set the display to show the percentage of charge...then when it's charged after a few minutes I switch it to powersupply mode for programming. I can't remember if you can set the supply voltage on the PL2320 or not. I know I can on the 6100 though.
Yes, it has the power supply option.
I knew nothing about this charger but it was recommended at the very beginning when this thread was birthed by Iceman.
Who could have ever predicted? Lol
Big Dog Daddy
New Jersey
Does your 22 have the larger battery tray like the 21's did. Were you can accommodate the larger battery that they were using with the now defunct diesels
