Kanuck
Winnipeg, Manitoba
Retired Electrician
Thanks to Fordphanatic, who looked for me, it took the dealership tech 4.5 hrs to update the IPC.
windowsmedia10
Toronto, CA
2024 F-150 Lariat Powerboost, 2025 Lincoln Nautilus
What's the latest on the use of the vxnano? Still not recommended anymore?
Mike G
N. AL, USA
After comments I've seen on the forums regarding that adapter I personally would not use or recommend it due to the alleged issues it causes with data corruption. I know the Mongoose costs more, but if the end result is a borked module update how much have you saved?
That's just my opinion.
"Steve"
"Steve"
NTX
21(1).302.PB.157.OX
anyone local need anything updated while i got the pass 2 more days?
Kanuck
Winnipeg, Manitoba
Retired Electrician
Do you make house calls to Canada?....LOL:LOL::LOL::LOL::LOL::LOL:
P.S. Bring your fishing gear.
Tbrak
Josh
Louisiana
2021 F-150
Plant Operator
So after months and months of waiting for the dealer to do something....anything. I'm finally Bluecrusin thanks to this guide! Much appreciated.
Quick curious question, according to FDRS I have no updates and I'm obviously up to BC but I still have no cameras at speed or the side panel camera. Anything I can do to fix that?
That's odd. If you have no more updates available you should have cameras at speed and the bed camera in the sidecard on Sync screen.
Are you sure that you don't have any DTC's currently?
Tbrak
Josh
Louisiana
2021 F-150
Plant Operator
I went out in the garage to go check, cranked the truck grabbed the laptop and cables etc. while it was booting up I flipped through the side card and well there it was. Not sure why it didn't pop up initially but I won't complain lol.
Feels good to be done....until the next time Ford screws something up! lol
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
The APIM needs at least one power cycle/reboot, sometimes two, to display any changes. Not sure why it is like that when other modules are not, but that's what I've seen. If I make a change to it with ForScan, I always do the module reset procedure after to force it to restart to help speed up the process.
JJ_Tex
Prosper, TX
2021 F150 Platinum Powerboost
Heck, if you still have the license, want to check my VIN: 1FTFW1EDXMFB09093
I've had 1 OTA since updating to BC, so I'm curious how well the OTAs are keeping up.
"Steve"
"Steve"
NTX
21(1).302.PB.157.OX
i can only check FDRS for updates pending not the OTA stuff in PTS. you don't have anything listed besides GSM (which should clear now).
mflynndelta
Cary, NC
2021 F150 FX4 Powerboost Platinum White 7.2kw pro
would you mind checking mine 1FTFW1ED3MFB23739
