FordConvert
I would try the TSB and retry the APIM. And always do a GWM first if one is available. Other than that the updates will trigger others if there are dependencies. Sometimes an overnight nap helps things. Stick with it and you'll get there!Welp, I'm not what one would call a "good reader" apparently and started installing my truck's updates in basically random order, which has now led me to a failed IPMA and a stuck APIM, which I've tried twice using the USB stick. Would y'all recommend I jump straight into the TSB for the stuck APIM, or maybe give it some time first? It's been about an hour so far since the last time I tried it. Also could initially running the updates in random order cause problems later on that I should be aware of? It doesn't seem like I can roll back to where I started, which might be a good idea.
P.s. you guys are amazing and the willingness of this community to help each other out is top notch.
