jperry5835
2021 F-150 Hybrid Platinum
Check on your web dashboard and make sure its not pending for 600 bux and really shows one year free. Check your about screen in your truck, make sure the last line also matches a one year free date...
how long did it take for the last line on the screen in your truck to update?
BHunted1
Sumner County TN
It hasn't. I’m not showing on my web portal and date is this October on about screen. No big nice blue welcome screen when engaging. You’re lucky.
Slappy McGee
South Caccalackey
2021 F-150 Powerboost
I didn't get any welcome screen either. Frankly, I couldn't find anything in the setup (I faffed around with the menus for a few minutes before hitting the road) so I assumed I didn't have BC enabled. I got on the highway to test lane keeping, hit the button, and was a bit shocked to see the BC magic kick in.
rpeterslll
Rob
Livonia, MI
2018 F150 Lariat FX4 Sport
IT Professional
Yes. @Jesse-Infotainment confirmed that for me. Same node.
ITRM = TRM ?
If this Recall refers to the TRM, the TRM is OTA updateable, why wouldn't they push this OTA? Plus TRM module is listed as "Exterior Lighting" in the Vehicle Module info , are we sure the ITRM is the same as the TRM and not just the lighting part of the trailer connector?
JEB
US
2021 F150 Lariat PB 502a
ITRM = TRM ?
Yes. We’re sure.
Ruffiano99
Joe
NY
2021 f150
Sooo good news and bad news for me.
Good news I bought a 2 days license anticipating just running to TSB. To find all these waiting for me even tho im only at sync 20312. Guess that means i can get Blue cruise even tho im way behind
Ford F-150 ECU module programming guide using FDRS 7A732715-8502-4F30-AC72-2F3ADA8307FB
Bad news is i got this message attempting the TSB and cant figure out why. I installed the drivers( or atleast i think i did) got to the part about plugging in the USB cable and this message came up…
Ford F-150 ECU module programming guide using FDRS B781B535-9ACB-4FED-9C68-6FC2CF47AB7F
The unfortunate part about having all those updates available is i dont have a mongoose. So im not prepared for them and i only have 2 days.
HELP! ?
20ecoboost21
Georgia
2024 F150 Platinum
Anyone have this happen, doesn't recognize key state. It will do this while checking codes and while trying to program modules.
Ford F-150 ECU module programming guide using FDRS Screenshot (634)
RapidRedRick
Rick
Northern Virginia
Ford F150 Platinum Powerboost
My last nano update was the CCM, I got through several stages and then it crapped out. Got the goose today and completed the available updates. Sync is now at 22034_364, no BC alerts yet but the night is young. I lost my heated steering - Cooled and heated front seats functions pre goose. The row of buttons under the HVAC buttons do not work. I have a DTC on SOBDMC :
SOBDMC - U0298 : 00
U0298 = Lost Communication With DC/DC Converter Control Module 'A'
FT : 00 = No Sub Type Information
I am also concerned that during the nano CCM update, the values in the IPMA got fouled somehow. Any ideas on fixing the SOBDMC DTC, and should I PMI the IPMA?
Ford F-150 ECU module programming guide using FDRS 1648677407992
travbz24
Travis
Iowa
21 F150 Platinum Powerboost
Cameras in motion (Bed, Hitch, Rear) does appear to be very trim specific. Mine 7D0-01-04 is 0xxx. For completeness Platinum. Totally update SW.
I think we have nearly identical builds.
Mine is at 0 in that field but I'm only getting bed and hitch, no rear.
Ideas?
JIMFOUNTAIN
Jim
Austin, Tx
2021 F150 SCREW PB 6.5' 701A
Ideas?
Goto the Forscan thread and follow the spreadsheet common tab info on Cameras at speed. These worked for me.
Ford F-150 ECU module programming guide using FDRS 1648679072263
Some of the other changes on this thread did not work for me. Others with different trims/options found they had to go a different route than these current spreadsheet entries.
JEB
US
Ideas?
If your IPMA fully up to date, try F in place of the zero. It worked for me and a couple of others but it’s getting hard to find consistency.
JEB
US
A word of caution. If thsee are the values from @Livnitup ’s FORScan spreadsheet, they might not be completely accurate for trucks that have undergone the most recent IPMA update. @Jesse-Infotainment noted that the most recent update brought Job 1 trucks up to the functionality of Job 2 trucks and that slightly different setting unlock more camera views. To determine what the best settings were for me, he found a Job 2 truck that was equipped like mine and made recommendations for changes.
travbz24
Travis
Iowa
I'm fully up to date. Do you know what those changes were?
JIMFOUNTAIN
Jim
Austin, Tx
Completely agree. My response was to @travbz24 because we have the same config. Cameras at speed need IPMA and APIM changes. The spreadsheet has different tabs for IPMA 2021 Job 1 vs Job 2 and 2022. 706-xx-xx stuff. And there may be more differences we haven't run into yet. We have noted apparent APIM (7D0) differences but they are not yet mapped out. Some combination of trim, options and SW level has bits behaving differently.
Can you post exactly what Jesse had you change plus your current SW and relevant options/trim in the Forscan thread? If we can capture it all we can eventually tweak the spreadsheet up so others can follow the trail you are blazing....
All: Please BACKUP before experimenting.
jordandev
Jordan
2021 F150 XLT 302A (on order...)
While I've been stuck at 21281 for the past few days, I had the APIM + IPC updates reappear. Running these just does the update check, then configure, then database update finishing in a few seconds each. Not actually applying any update.
These have reappeared 3 times now (about once a day). I've been running them, but should probably just ignore them...
Anyone else get this or does it point to something else going on?
