Buyer2021
- First Name
- Alan
- Joined
- Feb 9, 2021
- Threads
- 49
- Messages
- 3,136
- Reaction score
- 5,646
- Location
- central TX
- Vehicles
- 2022 Lariat SuperCab and 2005 XLT SuperCab
- Occupation
- retired!
- Thread starter
- #1
Posting just FYI
Drive Axle Shaft Assembly Set | 630-052 | Rear Axle Shaft Assembly Kit | Dorman Products
Amazon.com: Dorman 630-052 Rear Axle Shaft Assembly Kit Compatible with Select Ford Models (OE FIX) : Automotive
The much less expensive individual parts at RockAuto (total for the pair including shipping and tax is $566.24 to my Texas residence)
More Information for DORMAN 630051
More Information for DORMAN 630050
tagging @Snakebitten , curious to hear your thoughts
Me, I find this interesting, but I've not had a bolt break yet, still just chilling and waiting to see what Ford comes up with under the recall .....
Product Description
The bolts that secures the right and left rear hubs to the axle on certain 2021-2023 Ford F-150 trucks equipped with the Max Tow package have been known to shear off after day-to-day driving, a modest number of towing trips or ventures off-road. Failure symptoms include the sound of brakes that are dragging (a result of the brake rotor moving freely against the hub), a rattle caused by sheared bolt heads trapped inside the assembly and in extreme cases, severe changes in handling. The dealer solution is to replace axle assemblies with the same original equipment design, inviting a future similar failure. Our patent-pending Dorman OE FIX axle assembly eliminates the thin-walled internally-threaded axle end of the factory shaft design and the failure-prone bolt that connects it to the hub. The upgraded axle shaft features an externally-threaded male end and matching nut to capture the axle end, resulting in a more secure connection between the hub and the axle. The assembly is designed for a straightforward installation and a longer-lasting repair that can prevent potentially dangerous vehicle control issues and multiple dealership repair visits that can keep a customer vehicle out of commission for several days. This kit contains the axle shafts, spacers and nuts required to replace one left rear axle assembly and one right rear axle assembly. For only the left side assembly, select Dorman part number 630-050; for the right side assembly, select Dorman part number 630-051.
The expensive kit of both on AmazonAmazon.com: Dorman 630-052 Rear Axle Shaft Assembly Kit Compatible with Select Ford Models (OE FIX) : Automotive
