Both coolant reservoirs at min.
Davexxxx
MO
No puddles on the garage floor and I checked the oil. Not milky.
Keep an eye on temp gauges. All normal there.
Where is it going?
Also, at my local O'Reilly's Motorcraft coolant, is 30 bucks a bottle.
All I get from the owner's manual, is a motorcraft part number. Anyone know the current spec requirement?
Mosey
2021 F-150 Powerboost
The main coolant loop has been know to lose coolant for a number of reasons, most notably from the infamous heat changer. The amount that leaks can be small and may never result in puddling. Once your truck has cooled down get under it and inspect the heat exchanger closely.
Fox146
Dana
21 limited sold
Coolant does evaporate to some degree so it is normal to lose a small bit . I just topped up both bottles in my 21 back up to the full line.
Bunker
Idaho
2022 F 150 Powerboost Lariat
I used some ford points to get a bottle.
Hans Moleman
SF Bay
Oreilly is over priced. i bought a gallon from the dealer for $15
LCMM55
Larry
Myrtle Beach, SC
2021 F150 Hybrid Powerboost
I also just topped off my main reservoir, my 2021 xlt hybrid powerboost reservoir did not need topping.
Fox146
Dana
21 limited sold
After 4-5 years use a top off is fairly normal. I used the Ford stuff but as long as it meets the specs??
eharri3
Ed
Pa
21 Ford F150
Business
Miniscule openings in a system could allow a few ounces of evaporation over very extended time frames but if both tanks move to the min level quickly I would think in terms of a leak. My tanks on my 2021 have always been stable. My 09 Tundra needed topping off every few months or half year towards the end because the water pump was likely weeping.
wptorres
Will
Colorado Springs
2024 F150 XLT 302A 4x4 5.0 3.73 Antimatter Blue
My 2024 5.0 came with the coolant level at/below the minimum level from factory, is there a chance that is was low to begin with and just never noticed?
Davexxxx
Davexxxx
MO
No. I don't know when it dropped but it didn't come that way.
