Anyone planning on adding a Catch Can on their Ecoboost or Powerboost engine?
mdmeints
Minnesota
2013 Explorer, 2008 Sea Ray
The recommended oil in the owners manual is a SP specifiction.
You are correct, I am referring to the prior years that had the SAE SN or earlier oil specs.
tn.lariat
Murfreesboro
2024 Ford F150 Platinum Power boost 702a
Anybody install one on a power boost and where did you mount it? Looks like power boost system takes spot of normal mounting area.
Reeltime
Reeltime
James
Lake Fork, Texas
2021 F150, 2018 Murano
IT Consultant
I originally was concerned and did research. After I found that ford has modified its engines with an additional fuel injector before the valve, that solves the carbon build up issue and no need for catch can. These additional injectors spray fuel on top of the valves to help eliminate carbon build up. My 2 cents, for what it’s worth.
dwd125
Derek
PA
2021 F150 Lariat Sport (Max Tow)
IT
I don’t do *anything* to the engines of my late model cars. They are so tuned and set from the factory I think it’s a risk. No chips, no catch cans, nothing.
...and as far the any build up on the intake ... just have let the turbo live a little once in a while.
wayne
wayne
northern calif
2021 f150 platinum loaded, 2013 raptor
Just drive the damn truck or car like you stole it. It last longer than babying it. I have owned at least 15 new trucks. I want them to break down under warranty so they get fixed, instead of money out of my pocket.
Jerry Can
Calgary
2021 F150 KR Powerboost, 2-tone Rapid Red, 157”
Fuel Container
I also add a fuel injector cleaner every few thousand miles, so hopefully that will help.
I‘ve read that you’re not supposed to use fuel injector cleaners with ecoboost engines as they can damage the turbos. I would just stick with top tier fuel.
Jus Cruisin
Tim
Metro Detroit
Very retired
No catch can for this engine. Yes to my supercharged GT500.
Knickell
Mazda Protege, Ford F-150
Oh wow, good call. I will have to research that too! It’s been a maintenance staple for me with all of my previous vehicles, I certainly don’t want to do anything that is bad for it!
keithw1975
Keith
Missouri
2021 F150 302A, 2023 Explorer ST, 1999 Ram 3500
Our F150 and Explorer will never be out of warranty. There is too much stuff to go wrong, So we trade them every four years and keep them under Fords extended warranty. Our previous Explorer Sport had two timing chains and cam phasers replaced before 60k miles under warranty.
With what I am spending on these vehicles, paying an extra $1,900 to get bumper to bumper warranty coverage to 100k miles seems like a no brained to me.
Doyouevenboost
Brian
Minnesota
2002 Subaru, 21 f150 502a ecoboost
Utility maintenance worker
What’s your logic behind this? The ecoboost’s are pushing more boost than a gt500 in stock form. So in theory higher cylinder pressures would increase blow by.
Jus Cruisin
Tim
Metro Detroit
Very retired
Because the oil gets dumped into the supercharger and it becomes the catchcan.
Niterider
Shawn
Indiana
2021 F-150
factory worker
My grandfather always told me to "Blow the cobwebs out of it every once in awhile".
Those last few years he was around, every few months he'd throw me the keys to his 13' F150 and tell me to "Take it for a drive for me". I'd hear about it once I returned if I didn't tear out of the driveway like a getaway driver....
