Another RCSB build
JJC
Justin
KC
Website
www.instagram.com
22 XL RCSB
Picked up from @Granger Ford last weekend, 8/6.
Timeline from order to delivery:
✅Ordered 5/12 ✅VIN Rec'd 6/23 ✅Scheduled 7/18 ✅Built 7/21 ✅ Shipped 7/22 ✅ Delivered to Granger Ford 7/25
Specs as ordered:
XL RCSB - Agate Black - 101A - 2.7L Eco - 3.55 E-Locker - Fogs
Delivery day:
Ford F-150 Another RCSB build IMG_9067
Ford F-150 Another RCSB build IMG_9068
Ford F-150 Another RCSB build IMG_9073
Wheels & Tires:
RTX Oak 20x9 +30 offset -Raptor replica/style - I verified the weight @ 33.8 lbs each (since wheel weights are often hard to find)
275/55R20 BFG Advantage LT
-replaced the RTX center caps with black OEM Ford caps, p/n: FL3Z-1130-L
Ford F-150 Another RCSB build IMG_9180
Ford F-150 Another RCSB build IMG_9149
Ford F-150 Another RCSB build IMG_9177
Ford F-150 Another RCSB build IMG_9182
Ford F-150 Another RCSB build IMG_9181
JJC
JJC
Justin
KC
Website
www.instagram.com
22 XL RCSB
I've got all I need to get it lowered, too hot for me to install right now, maybe next weekend. I will be using Belltech front struts for 1-3" lowering and their 4" flip kit. Ideally I'll drop it ~2/4 but could go as low as 3/6. Just wanted to have the option of a 4" rear drop (which includes lift hangers +1" and lift shackles +1").
Ford F-150 Another RCSB build IMG_9157
JJC
JJC
Justin
KC
Website
www.instagram.com
22 XL RCSB
Ordered Air Design fender vents (VML3Z-16228-AA) & BAP front/rear emblems (LL3Z-9942528-B). Will update this post once I get them installed.
Rockman5159
Rocky
Marion SC
2021 ford f150 FX4
Picked up from @Granger Ford last weekend, 8/6. They not only honored the 3% below invoice, but also stacked $3500 in available rebates @ delivery; kind of feel like I stole it :ROFLMAO:
Specs as ordered:
Delivery day:
Wheels & Tires:
NICE TRUCK!
  • Like
Reactions: JJC
Graygoose2021
Oklahoma
Sales
Great build so far!!
JohnMcClane
Lower 48
If you live somewhere extremely hot, the fender vents are gonna disappoint.
JJC
JJC
Justin
KC
Website
www.instagram.com
22 XL RCSB
Belltech 2/4 installed.
Measurements to top of wheel arch:
Front 36.5" before & 34.5" after = 2" drop
Rear 40" before & 36" after = 4" drop
3.5" of rake down to 1.5"
Belltech's chart for the front struts is not entirely accurate. I followed their example of using (2) 16mm rings per strut hoping for a ~1.5" drop, but after settling I've net a true 2" drop. Not really a big deal, I just haven't seen it mentioned by anyone else. I'm certainly not taking the front apart again just to raise it 1/2" :ROFLMAO: The flip kit was simple enough to install and net a true 4" drop as intended (I installed Belltech 6447, which is technically for 13th gen but everything worked out fine). I also added shorter Fox 2.0s the rear.
Ford F-150 Another RCSB build 1662228773130
Ford F-150 Another RCSB build IMG_5931
Ford F-150 Another RCSB build IMG_5943
Ford F-150 Another RCSB build IMG_5929
Air Design fender vents & BAP emblems installed as well.
Ford F-150 Another RCSB build IMG_5949
Ford F-150 Another RCSB build IMG_5935
Ford F-150 Another RCSB build IMG_5934
Ford F-150 Another RCSB build IMG_5936
*Obligatory @Granger Ford shoutout :LOL:
Davidwnuc
Mississippi
On order ‘22 RCSB.
Looks great!
How does it ride? i have, essentially, the same suspension parts awaiting the arrival of my RCSB, so I’m curious what you think.
Thanks for the info.
  • Like
Reactions: JJC
dolsen
KY
2022 Rapid Red 701A
I REALLY like the raptor replica wheels
  • Like
Reactions: JJC
Rockman5159
Rocky
Marion SC
2021 ford f150 FX4
Specs as ordered:
Delivery day:
Wheels & Tires:
WOW what a transition.Its in STEALTH mode now!
parkerdog
Illinois
f150
That looks sharp! Pretty quick time getting it too.
I too like the looks of those wheels, can you get them in silver? I didn't see any on the site I was looking on.
  • Like
Reactions: JJC
JJC
JJC
Justin
KC
Website
www.instagram.com
22 XL RCSB
Talked myself out of cutting up a perfectly good BAP grille just to fill the upper notch in.. I also looked into Tremor/BAP hoods and found out the vents are faux, so that wasn't going to happen :ROFLMAO:
Instead, I picked up a Lariat grille, cut away the vertical bars and replaced it with XXL Hexagon Mesh from CCG. Really happy with how it turned out. I've got new headlights on the way so I'm waiting until those arrive to get both the grille and lights swapped out. Should look good!
Inserts removed.
Ford F-150 Another RCSB build IMG_9773
Rough progress of cutting away vertical bars + the mesh I used.
Ford F-150 Another RCSB build IMG_9809
Finished product w/ Agate Black painted bars & mesh fitted/attached.
Ford F-150 Another RCSB build IMG_9839
Ford F-150 Another RCSB build IMG_9838
JJC
JJC
Justin
KC
Website
www.instagram.com
22 XL RCSB
Switched out the lighting all around.
AlphaRex PRO Series Alpha-Black Projector Headlights 880294 purchased from @Stage3Motorsports
OEM LED Fogs, used (2) Motorcraft pigtails (WPT-925) to complete install
*applied Lamin-X Gunsmoke film to get a better match with the AlphaBlack headlights
Full Set LED Tail Rear Lamp Taillight Assembly Compatible with 2021 2022 Ford F150
*Link to tails on Amazon
LED 3rd Brake light for Ford F150 Smoke Lens (2015-2020 F150)
*not plug-and-play for 14th gen. I reused the OEM connector, cut and spliced to new brake light
Ford F-150 Another RCSB build IMG_9770
Ford F-150 Another RCSB build IMG_9899
Ford F-150 Another RCSB build IMG_9905
Without Lamin-X installed
Ford F-150 Another RCSB build IMG_9926
Ford F-150 Another RCSB build IMG_9927
Ford F-150 Another RCSB build IMG_9951
Ford F-150 Another RCSB build 44CB9F60-8188-4D82-AAAF-65D3ECFD7BD7
Ford F-150 Another RCSB build 60910320-E80C-4602-94D2-712057BC800D
Graygoose2021
Oklahoma
Sales
Looks great, see my post about Trim Illusions door handle covers? They'd match perfectly, and they soon will have gloss black mirror caps.
  • Like
Reactions: JJC
