Adding a Sub to non-unleashed BO system
Graygoose2021
Oklahoma
Sales
I just changed sub setup in my F150, anyone looking for a SG sub box, will be selling mine.
Great output on this enclosure
Ford F-150 Adding a Sub to non-unleashed BO system 20230424_144841_resized
Abraham5G
Abraham
Houston, TX
What subs are included with this box and how much shipped to Houston, TX?
Graygoose2021
Oklahoma
Sales
Hey, on the road now for work in San Diego. $450 shipped, comes with Kicker Comp RT 6.75" subs.
With 400-500 watts, this thing rocks!
Graygoose2021
Oklahoma
Sales
Spaced25
john
vr
2025 f150 Lariat
There is roll off like any factory system, but I think the bigger issue is the ANC (active noise cancellation) with either B&O setup. I thought I was hearing things to begin with, but a few other threads on here sorta confirm it, but the mic and DSP in the cab will even start to dial back the bass after a few seconds if you notice. Play a really heavy bass song, or even just a low freq test tone, turn it up, and after a few seconds you will here it get quieter. I haven't messed with it yet but you can go in with Forscan and disable it, but hopefully that doesn't hamper the system more overall.
I’ve noticed this with the stock B&O 8 speaker setup and it’s driving me nuts. Knew there was something going on! Bass drum changes in the same song.
Are you getting signal from the wires feeding the factory amp and this still happens with the hideaway?
Also, did you ever wind up adding an LC2i or KEYLOC?
I’m about to order a 10” hideaway but not sure about the KEYLOC or similar. Just trying to get this sounding closer to the B&O that was in my 19 lariat with the 8”in a vented box.
EcoBeastCA
2023 402A
You need a Zen Audio NAV-TV my friend.
(Despite SGS' description it isn't a "mandatory" upgrade, however it makes a significant difference in tonal quality such that if you have above-average audio perception, you should get one)
Spaced25
john
vr
2025 f150 Lariat
I have a good ear but not quite audiophile level.
Again, just looking to get closer to what my 19 sounded like, full with some punch across a wider frequency.
Is there anyone that added just the kicker hideaway and didn’t feel it was worth it over the factory sub?
My current thought is
  • 10” hideaway
  • harness from SGS to get the RCA near the factory amp
  • SGS plate
  • Sound deadening for the rear of the cab.
I could always add the KEYLOC after.
that$pit
Tennessee
2023 f150 3.5l ecoboost tremor
  • 10” hideaway
  • SGS plate
I recommend the keyloc and SGS's wire harness. I used that with a mono amp and 12" RF punch shallow mount sub in home made box under the rear seat. Made the install a little easier. And i chose the keyloc over any other line output converter due to the bass roll off elimination. And with the pre-tuning SGS does, i felt confident that i wasnt entirely cutting corners as a novice car audio person.
Sounds good enough for me and got back to that 'feel your music' sound. I tried a full size sub i had and it was a terrible match. Too much compared to the rest of the system, even at minimum volume.
Spaced25
john
vr
2025 f150 Lariat
I have a question on the DC offset Turn-On option for the hs10. It states it only works with the high speaker level outputs.
If I’m getting the audio signal from the factory sub wiring, can I use the high level speaker input option, or would I need to use the low level since it’s already filtered for lower frequencies?
Graygoose2021
Oklahoma
Sales
You can use either
Ford F-150 Adding a Sub to non-unleashed BO system 1762890906652-4k
Spaced25
john
vr
2025 f150 Lariat
You can use either
That’s where I got my info. What’s not clear to me is if I can use the stock sub signal and set it to high-level input knowing the signal is already modified for a sub. My preference is to use the DC offset to avoid tapping a a switched turn on lead.
Graygoose2021
Oklahoma
Sales
Well not sure what the stock signal is, but you should be able to. They are pretty easy, power/ground/signal
And soon, we will have a bigger one...HS12. :)
Bob Violence
Bob
TX
2021 F150 Lariat 501A FX4 Powerboost
On the amp, high level and low level inputs don't refer to the frequency range, they refer to either a full power input (high level) or a pre-amp input (low level).
In your case (and my setup as well), if you are using the wires that feed the stock Ford OEM subwoofer as the inputs to the amp, those are high level power, even though they are only sending a low level frequency. Confusing I know.
Ford F-150 Adding a Sub to non-unleashed BO system Captur
Spaced25
john
vr
2025 f150 Lariat
Ah, didn’t realize it wasn’t referring to frequency. Thanks!
