Adding amp and sub to unleashed
Tremor724
Pittsburgh
2022 Tremor F150
I’ve read through multiple posts about adding a sub and amp to the unleashed system, bass roll off and other issues.
What’s the updated thoughts on what’s needed, I have an sklar underseat box and amp I’d like to add to my 22 tremor.
I see some thing mentioned about making changes in As built for the roll off, is that sufficient and are there any plug& play harnesses to get the signal from the factory amp ?
thx gentlemen.
Graygoose2021
Oklahoma
Sales
A Kicker KEYLOC will fix the bass rolloff and flatten the factory EQ curve for the amp.
rugedraw
Javier
Miami
Auto Sales
In my case, the bass roll-off was eliminated with an LC2i.
Wmflyfisher
Wesley
Inlet Beach FL
2019 F150
So where do you connect the KEYLOC or pull the wires from? Is this all you need to then run RCA’s, power, remote and negative to the sub amp?
