2022 F150 Unleashed Sub Issue and question
YouPutz
Wisconsin
2022 F-150 Lariat 502a 3.5 Max Tow BlueCruise
Hey guys,
Have a bad rattle in the sub speaker, so I suspect its blown. Had the screech and pop issue several times. I also read the threads about window rattles and TSB and this is not the particular case. I took the speaker out and it sounds terrible.
I may ask about warranty but never have any luck with anything subjective like this. The speaker would have to be in flames and fall out of the truck and then the dealer MIGHT admit that there could be a problem...lol!
Anyways I read a lot of threads about all the nice and expensive sub upgrades, not sure if I want to get into all that with this truck.
I'm curious, is there just a better speaker I can buy and put into the stock location without getting into amps and all that? What size is that speaker?
Ford F-150 2022 F150 Unleashed Sub Issue and question truck1
There's ways to kill a speaker if the dealer thinks it has too much life in it.
Eskram
Fl
2022 F150 Lariat PB 502a
120v to the speaker terminals says whaaa?
Pro-tip: Do not do this while it's attached to the vehicle.
Eskram
Fl
It'll play 60hz like it's never played it before!
Ford F-150 2022 F150 Unleashed Sub Issue and question 1723841866184-7z
But to answer OP's question - I do not believe there is an aftermarket drop-in that would improve the sound. You would need to go with an aftermarket setup.
YouPutz
Wisconsin
Went to the dealer and they actually agreed that the sub sounded blown and ordered a replacement.
