Add Heating Steering Wheel to 24' XLT
CarbonMark
WA
2024 F-150 XL Regular Cab
The issue why the SCCM doesnt work in the 24 with the 24 part number initially is the SCCM is part of the encryption network..
I dont remember the 23 SUper duty having the SCCM part of it.. but none the less in a 24 if you install a new SCCM you need to have the sccm authenticated.
I just found out helping someone out with this. Saw the message error DTCs.. and knew right away..
How is the authentication performed, can it be done with FORScan?
Jesse-Infotainment
Jesse
2024 F150 Lightning
How is the authentication performed, can it be done with Forescan?
Dealer only FDRS. NEVER will be available any other way
Let me make an edit. I never say never. I should clarify and say its unlikely.. BUT there is always a chance. THe issue is the agreement takes place on Fords end. It resets the keys and sets the keys in the modules that hold them.
THe Encryption is the big reason that the PCMs cant be tuned at the moment for a super charger or other performance.
One truck that does have a whipple on it the Cluster displays Certified Calibration to let the dealer know that it is indeed a Ford authorized tune.
We would have to really dig into the TRON process and do some things to be able to copy it but since it reaches out to Ford servers.. its going to be hard to duplicate.
CarbonMark
WA
Use the 24 sccm, I did the swap on my 24 XL with Jesse's help. If you haven't done the wiring I am selling the harnesses to land in factory locations $150 shipped. I did it myself and went to the dealer for authentication, be prepared to go since your turn signals, high beams, or wipers won't work.
Sound like you have one of the first 2024 trucks with the Heated Steering wheel retrofitted!
What did you ask the dealer to perform -Did you simply tell them you swapped in a new SCCM and needed it authenticated to the truck? How much did they change you for the service?
JayBob
Jared
VA Beach, VA
'23 F-150 Tremor 401A 5.0
Military
24 uses a new SCCM. Cant use 21-23 difference in Canbus
Hey boss. I have a question regarding my '23 tremor 401A. Is this (PL3Z-3F791-AB) the proper SCCM I need for my truck? I am going to attempt a heated steering wheel upgrade. I am assuming mine doesn't have the wiring already bc it's a mid-level trim.
Je1279
Jared
Upstate NY
Jesse-Infotainment
Jesse
2024 F150 Lightning
21-23 are same.. there is good thread for those years.
Part number ends in BB
I checked a few dealers and they all have BO (RL3Z3F791BA), Do you know a place where he would have it?
I dont. I havent bought any yet.
Jesse-Infotainment
Jesse
2024 F150 Lightning
My local dealer say
RL3Z-3F791-BA has been replaced by SL3Z-3F791-BA
Correct for my 24' SL3Z?
S would be 25.. so its totally possible they superseded
SL3Z3F791JA
THis is the part number I pulled
2024 is still showing
RL3Z3F791BA as a valid part number
popeye2856
Rick
Wichita Falls, TX
2024 F150 Regular Cab
Retired mailman
So I have a 24 RCSB XL. Just ordered a new wheel to replace the 40 grit sandpaper wheel. I got a heated wheel hoping I could get it activated someday. If I understand correctly I just need to get the correct 2024 SCCM and then I can swap out my HVAC controls. Do I have to get a 2024 HVAC control unit or can I use one from 2021-up? Does every new electrical part have to be authenticated on 24' models? What a pain in the ass to try to make these into decently equipped trucks when we could live in Mexico and buy a Lariat RCSB! :mad:
MY 5 OH MY
Richard
Puyallup Wa
25 F150 XL
neuro trauma ICU nursing
are you still selling the harnesses, and will they work on a '25 XL
22SpaceWhiteXLT
Chad
Tampa Bay
2022 Space White XLT Sport
Can anyone confirm if this wheel (ML3Z3600RA) is real leather or the cheap stiff fake leather? I ordered the Tremor ML3Z-3600-VA wheel on the recall and while it was nice with the orange stitching and shiny bezel, it was fake leather/vinyl like my stock XLT wheel so I sent it back.
sport19
Kansas City
2024 F150 RCSB, 2019 Fusion Sport
My local dealer say
SL3Z-3F791-BA is the right part. I was able to install one into my '24 XL this weekend. I copied over the forscan values from my original SCCM, then ran a PMI in FDRS and then I ran the the TRON network repair. Interestingly, the PMI and TRON process both failed, but the SCCM seems to work OK with no DTC's.
sheesh
Marcos
Seattle, WA
2024 Ford F-150 RCSB, 2023 Audi SQ5
I can confirm that the SL3Z-3F791-BA is the right part. I did the same process. I got mine working in mid-April. It not just the SCCM and steering wheel (ML3Z-3600-RA), you will need a harness to connect that heating element. You are required to change the UI to have the soft button which I really hate the design of.
Also make sure you are running the latest version of Forscan.
sport19
Kansas City
Do you happen to have the list of forscan changes to enable the soft button? I am still working through the spreadsheet looking for hsw references.
