Add Heating Steering Wheel to 24' XLT
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Do you happen to have the list of forscan changes to enable the soft button? I am still working through the spreadsheet looking for hsw references.
Sheet in my sig
cbrfromhell
2024 F-150 XLT Powerboost
So what all was required to make this work for a 24 f150 powerboost 303a trimed truck?
TheDudeee
Samad
North Dallas, TX
2024 Ford F150 XLT
I can confirm that this part number given SL3Z-3F791-BA also works for me too. Ran the TRON and it went successfully less than 5 mins. Was able to do forscan to load the factory as built and used superfordman's sheet. Then I got a working heated steering wheel in......summer time.
sport19
Kansas City
2024 F150 RCSB, 2019 Fusion Sport
As a followup, it looks like the 2024 trucks (at least XL and XLT) need a different HVAC setting changed. I chatted with @TheDudeee who confirmed the same. Instead of 733-01-02, I needed this change:
HVAC - Vehicle contains a HSW 733-01-04 - xxxx xxx4 xxxx - (My original Value: 0)
MY 5 OH MY
Richard
Puyallup Wa
25 F150 XL
neuro trauma ICU nursing
to anyone who has had a new SCCM authenticated for the heated steering wheel upgrade how was the process, my local ford service center has been giving me some push back, saying it may not work because it was not part of the "as Built" based on my VIN. Also that it could be "Hours" $$$ to do it correctly.
any help would be great.
TG587
Western Canada
2025 F150 XLT
Not sure exactly how the process will go for me, but when I do it, I'm going to buy or rent a mongoose cable, pay for the 2 day FDRS license and try to do it at home.
Curly
Curt
Mn
2024 F150 PowerBeast
Problem Solver
Mine was $250.00, Tell them you need your new Sccm Authenticated with Tron
Verified from Livnitup;
SCCM 724-01-01 xxxx 8xxx --
HVAC 733-01-02 xxxA xxxx xx--
IPC 720-05-02 3xxx xx--
APIM 7D0-02-01 xxxx 5xxx xx--
733-01-04-XXX-XXX4-XXXX for the heated wheel tab on the bottom
of the productivity screen.
i added the following and still have a code maybe from my cobbled connecter
Ford F-150 Add Heating Steering Wheel to 24' XLT 20250901_190410
TheDudeee
Samad
North Dallas, TX
2024 Ford F150 XLT
SCCM B112B:49Steering Wheel Module: Internal Electronic FailureThis DTC sets when there is an Internal Electronic Failure in the SCCM . This may happen due to a fault on the heated steering wheel circuit.
Is the heated steering wheel working for you? You might want to recheck the wirings and check the powers for pin 2 from the new connector.
Curly
Curt
Mn
Problem Solver
I will do that. Do you know if during the authentication the tec would have to set a parameter for the heated wheel?
TheDudeee
Samad
North Dallas, TX
2024 Ford F150 XLT
Nope, TRON will take care of that. It is checking all of the current and new modules then correct and register to the vehicle.
I am pretty sure that the tech will tell you after TRON that the tech is unable to do PMI on it because of different part number.
TG587
Western Canada
2025 F150 XLT
I found this connector on Amazon and it worked!
I have a working HSW!
Yes, I used the same one on my 2025 XLT and it worked well. Big thanks to TheDudeee for all of the insight, help and tips.
Also big thanks to Blown F-150 for lending me his Mongoose cable!
Curly
Curt
Mn
Problem Solver
Is there a forscan change for the HWS to come on automatically at a certain temp?
