2025 - How to Add SecuriCode
Confused
US
2025 F-150 Tremor
Did you make the changes with Forscan?
FirstTimeFord
I’ve tried many times, very slow, very fast, very very fast, FOBs inserted different ways, nada.
Try this, maybe the button direction of the fob in the slot? Are both fobs currently programmed to the truck?
Ford F-150 2025 - How to Add SecuriCode 1759920671527-ja
sixpt6
Adsm
New Jersey
2025 F150 Raptor
Did you try making the FORScan changes first then getting the factory code? Worth a shot.
DGChuck
Chuck
IL
2018 XLT
After you installed the keypad, and updated FORScan, did your Sync screen present the factory code or request it? Or asked another way, at what point is the factory code needed?
Thx, this is the best step of steps I've seen,but tried it again this AM with same negative results. Since the key code is blank on my BCM module, I'm wondering if Ford stopped assigning key codes, if they're only used for the key pad which the 2025 don't have???
FirstTimeFord
Thx, I agree with your suggestion, have not done it yet but will give it a shot.
Grok says you need to do in this order:
1) Install Keypad
2) Make FORScan changes
3) Retrieve code using Fobs
digitaltrucker
Ed
2021 F150 Platinum, 2013 F150 Lariat, 2008 F150 Lariat, 2005 XLT, 89 F150 Lariat
You can’t get key code until installed and programmed.
sixpt6
Adsm
New Jersey
2025 F150 Raptor
And just FYI, I have a ‘25 as well and the spot on my BCM module for the code is blank as well, first place I looked lol
BringBackTheKeyPad
2025 XLT
I have a 2025 i got a month ago and i had the factory code and everything was fairly smooth and exactly what i expected based on this thread
i did do the procedure to get the code after activating the keypad with forscan. I activated in 2 different spots i believe.
BringBackTheKeyPad
2025 XLT
having the keypad is the best thing about owning a Ford. I was between an f150 and a different brand and I am so glad I went with the f150 just on the keypad.
FirstTimeFord
Don't ruin the board with AI slop.
The instructions are accurate. I reference the source for transparency. This site and most likely this thread were crawled to confirm the information. I get your point though. "Keep it real". This response was not generated by ai, for the record 🤪
DGChuck
Chuck
IL
2018 XLT
DGChuck
Chuck
IL
2018 XLT
So I ordered the keypad Ford said matched my VIN, the RL3Z-14A626-AA, it's being returned at Ford's expense, the connector is wrong. I'm going order what I should have, the FL3Z-14A626-AH that everyone has installed successfully. Should have listened to other owners not Ford. Interesting the part is for a 250, but fits the 150 connector.
boatnfish
United States
2025 F150 King Ranch, 2021 BroncoSport
Okay, great thread here, thank you to everyone who had input.
I picked up the key pad and trim panel for my 2025 King Ranch today. I ordered the two parts identified at the start of this thread.
After reading this entire thread, took me about an hour to install the hardware. I started with the door panel so that I could verify the connector matched. As mentioned, I was able to remove the original trim panel without removing the exterior horizontal piece along the window (I did remove the T20 screw).
With the trim panel off, I snaked the key pad connector straight down. While slightly turning the cable it moved down easily. I was able to connect it to the connector and attached the retaining clip closest to the connector. The other one I was not able to feel (blind location) where to attach it. With the key pad wired, I put the trim piece on then reinstalled it to the vehicle. More great advice to place a towel over the window hole when installing the 4 bolts for the trim piece.
Using Forscan I activated the key pad, wired. Getting the hard coded key code was easy, and it displayed until ok was pressed on the steering wheel.
I was a little disappointed that it unlocked all doors at once, instead of just the drivers door, then the rest when the other number is pressed on the key pad. After playing around, I found that was set on the infomat under the setting to unlock all doors (not just drivers) when I would walk up with the key FOB. Changed that setting and it works as I expected.
In Forscan I used the easy setup method. Afterwards I did look at the APIM and BCM address for the key pad and noticed that they don't match what is in the livinitup spreadsheet. Not sure why, but it does work.
Great guidance from everyone, thanks again. This made the installation quick and easy.
