FirstFord
- First Name
- Jeff
- Joined
- May 14, 2022
- Threads
- 65
- Messages
- 771
- Reaction score
- 675
- Location
- South Central Missouri
- Vehicles
- 2022 F-150 Lariat SuperCab 502A, 4x4 3.5 EcoBoost
Nice write up, by the way!
There are still a detail or two that are not clear to me...
https://www.holley.com/products/drivetrain/transmission_pans_and_accessories/ford/parts/70400
I viewed all 8 photos of the pan that were on display, and read the "Overview" as well as "Features". I didn't read anything about a fill port and didn't see anything in the photos that looked anything like a fill port. What am I missing?
Great detail pic of the dipstick, and great explanation!I just had a thought, and I'm probably coming from "left field", but could the numerical markings on the dipstick be indicative of the number of quarts of fluid that need to be added? Just a thought...
I was unaware of this, and found this concept to be an interesting approach. I went to the Holley / B&M website for a closer look:You don't use the 3/8 tube to fill the whole transmission, there is a "fill" port on the side of the new pan, assuming you will use a deep sump pan!
I have read in a number of threads that this can be quite a challenge. My transmission typically sits around 195 (+/-) degrees. Only when I'm pulling a decent weighted trailer does it it get close to the 204, and I know I'm not alone. On the one hand, it is something to be happy about, compared to the opposite scenario, but it makes checking the fluid level properly almost impossible. So, the process for me will be to load up a trailer, tow a trailer for quite awhile, come back home, unhitch the trailer, raise the truck and check the fluid level with the dipstick. It seems to me that Ford could come up with a better way to perform a basic maintenance task! ?YOU MUST GET THE TRANS TEMP UP TO min of 204 degrees to get a good level check
