Suns_PSD
Well, he doesn't work on F150s so it would require some processing. He also has a toolkit with different fittings and what not for this procedure. But I'm pretty sure he just disconnects from the trans cooler, which I presume the F150 has but maybe not?Might he share with us exactly which line he uses for this procedure?
I have to say again, that even though I only swapped out 42% of my fluid, it has made a profound difference in shift quality. I'm going to swap at least one more time. Unfortunately, 42% of the fluid I'll drain next time will be nearly new so the effectiveness of these fluid swaps will continue to drop. If I drain another 5.5 quarts next time, only 3.2 (58%) quarts will even be the OEM oil. The next time, even less.
If I was doing it again from new, I'd just swap out exactly 1 gallon of trans fluid every 3rd oil change (I run full intervals on my oil change intervals) indefinitely. As it is, I'm going to swap another 5.5 quarts of trans fluid at the next oil change and then I'll just go to swapping a gallon of ATF every 3rd oil change or so. If the fluid ever starts to come out red and clean again (doubtful) I'll move that out a bit.
