Angrybeaver
A quick follow up on this and it is probably more just to make me feel better.
The small print on the towing and rv guide ford published says equipment changes Yada Yada and to check with dealer for exact numbers.
I called my dealer and they assured me my tow is 11,300 despite having the class 4 hitch and the brake controller added on as an additional item.
I explained my concern and was informed that the only difference between my setup and the "tow package" was the inclusion of the easy backing add-on. Not sure how factual that is, but was the information given.
My Brother in law has a 2022 with the tow package and we compared the areas mentioned here. Springs/shocks are identical except I have the monoshock in rear due to fx4 package, but rating are the same. The numbers on brakes, frame, sway bar... same. The radiator is also the same. The only thing I didn't check and will need to figure out where to look is the parking brake.
Oh I do have 20" rims compared to their 18s, but that doesn't seem to be a limiting factor either.
Part of me wonders if it is the brake controller not being present by default... though 7k is much higher than the 3k required before trailer brakes in my state.
