Tow Tech vs Trailer Tow vs Max Tow packages?
D87302
Joe
Hudson Valley
2008 Mustang Bullitt; 2021 F150 XLT 302A SCrew...
I cant find the answer on this one. Ill keep looking. I went with the 20's because of personal preference, so I never even noticed the issue doing my build
Thanks, and please do reply when/if you find out. The Lariat Standards 18" wheels are good-to-go with MaxTow. XLT Sport's 18" wheels are good-to-go with MaxTow. 2021 XLT 301A MaxTow is good-to-go with included 18" Silver Painted Aluminum Heavy Duty Wheels - and now in 2022 that is no longer the case? It's looking like there's something unique about the 18" chrome-like PVD wheels that makes it a fitment no-go. Or does Ford have stubborn marketers or a greedy OCD designer on their hands?
D87302
Joe
Hudson Valley
While continuing the research I may have found the answer to The Question.
All things being equal - it turns out the 18" Chrome-like PVD wheel is not.
All the other wheels I had under consideration and subsequently mention have these measurements in common:
Size: 18" x 8.5", 6 Lug, 135mm Bolt Pattern, 44mm Offset
or
Size: 20" x 8.5", 6 Lug, 135mm Bolt Pattern, 44mm Offset
The 18" Chrome-like PVD wheel is Size: 18" x 7.5", 6 Lug, 135mm Bolt Pattern, 44mm Offset.
I suppose those different dimensions make it incompatible. I don't know, I assume so though.
But why does Ford no longer include and allow 18" Silver Painted Heavy Duty Wheels on the XLT 301A with Max Tow option? Could it be that...
Adding Max Tow Package ($1995.00) to a XLT 301A being built using 2022 on-line build tool defaults to the requirement of adding the Chrome Appearance Package and 20” wheels, increasing the subtotal in that moment by $5,085.00!
Bottom line: building the XLT my way, getting most all features I want but avoiding the Max Tow Pkg. to avoid the 20” wheels (w/Chrome Pkg.) resulted in comparison to a grand total $2,435 up charge to the Max Trailer Tow Package ($1,995.00) , effectively making the actual COST of Max Tow for me - $4,430!
As I previously said, last year MaxTow came with 18” HDPP wheels (+ $95.00).
I’m starting to not like Ford.
D87302
Joe
Hudson Valley
larger brakes? the reason, I don't know about that... lose the 302A Chrome Package and your Max Tow vehicle will come with 18" Silver painted Heavy Duty wheels. More likely the 20" wheels are a substitute for the "heavy duty" 18" wheels - while maintaining the "chrome" look to match with the chrome package aesthetics. An 18" "chrome like" PVD Heavy Duty wheel would be a better option to offer!
EDIT: I had since learned that the 18" "chrome" wheels are a different dimension than say the sport wheels and painted HD wheels... so 18" chrome (302A) won't cut it. I changed my 2022 order to a sport package XLT 302A. There's always something!
Calson
Monterey CA
I have the 2022 with the Max Tow package and the ride it provides is softer than with the Chevy Traverse SUV it replaced, and the Chevy had a better ride than my Mercedes coupe. With 35 PSI passenger class tires the ride is not at all truck like.
The max payload package that adds a third leaf might change the ride but this would be easy to fix by adding a rear sway bar to the truck.
JimMoran
Jim
Bloomer, WI
2004 T-Bird, 2020 Explorer ST, 2022 F150 Lariat
I had a 2022 XLT on order with tow package, and snow plow prep. After waiting over 7 months found a Lariat with snow plow prep, and max towing package. The one positive I found is that with the upgraded springs my front end did not drop as much as my 2018 with just the towing package. Only complaint I had was the front and rear suspension seemed to be not in sync. Have read many complaints about this. Replaced the shocks with a set of Bilstein shocks and the truck now has a beautiful ride. Never thought I would say this but I am sold on the max towing package.
