Solved - LED projector swap no high beams
dolsen
KY
2022 Rapid Red 701A
I just installed some LED projector headlamps and the high beams are always on. I cannot turn them off. I also have several DTC’s. Does anyone have any insight? @Livnitup @JScaro or anyone else?
Ford F-150 Solved - LED projector swap no high beams AEAF89FA-851F-4D3F-8E0F-83E9870B7675
Ford F-150 Solved - LED projector swap no high beams E7096A96-1DC8-45BC-A5DB-8BF325341E8A
Ford F-150 Solved - LED projector swap no high beams 0C9D7136-CE7C-4F84-A2AD-0BD15B323E49
Ford F-150 Solved - LED projector swap no high beams F625A582-1D22-4A31-B8BA-3592AF99BC76
Ford F-150 Solved - LED projector swap no high beams BFDC00EA-007A-429C-9A74-DC953EF0DF6E
Ford F-150 Solved - LED projector swap no high beams 3F0689BB-0C57-420B-B9CB-39DD1CF035B1
Jesse-Infotainment
Jesse
2024 F150 Lightning
Did you verify the harnesses were installed on the correct sides?
also thE HCM may have thewrong software if it has not been PMI
dolsen
KY
2022 Rapid Red 701A
I installed them as they were labeled, but I wondered if they were reversed as well. If I swap them (assuming they’re currently correct) would it hurt anything?
I got it from ryan industries and he did PMI it before hand.
Jesse-Infotainment
Jesse
2024 F150 Lightning
I wouldnt swap them..
Not sure his process for PMI and there are several software version for HCM.
Hard to say.. COuld bbe a pin out error in the harness. Could be a few things. Its hard to help on this one as I cant see anythign
dolsen
KY
2022 Rapid Red 701A
I originally got this harness and thought the wiring was incorrect looking at the pin out, but I assumed I just didn't know what in the hell I was doing because I have never wired up a connector before. But looking at the diagram vs the connector, and with the issue I am having, I think it may actually be wrong. There are wires in holes that are "NOT USED" and some others missing wires that probably should have them, for example, but pins 6 and 14 have a wire running to them
Ford F-150 Solved - LED projector swap no high beams 1672443379527
Ford F-150 Solved - LED projector swap no high beams 5FEDE8A0-7147-4040-858D-D0C9272D1328
Jesse-Infotainment
Jesse
2024 F150 Lightning
Maybe you got the wrong harnes.s You had LED> possibly they sent you Halogen to LED>
Mind you I havent looked at the pics yet just throwing it out there. Ill look at the pics now
dolsen
KY
2022 Rapid Red 701A
To clarify, I was just made aware that with the projectors, both of them are on when running low, which I didn’t know, so I suppose it’s possible that the high beams just won’t turn on
Jesse-Infotainment
Jesse
2024 F150 Lightning
The harness doesnt look correct to me. You have quad LED>. Pin 6 is Lin bus for Quad LED but hte Projectr do not use Pin 6 they have pin 5 ru to the HCM it controls the High beam and bending.
That diagram isnt right you show either
Jesse-Infotainment
Jesse
2024 F150 Lightning
Oh yeah.. Low beam does have both on. The top seem sa little dimmer than the bottom but yes both are on.
antho
Anthony
Houston, Texas
2024 Raptor 37
So when you turn the high beams on do they get brighter? You are correct that all 4 projectors will be lit at low beam.
dolsen
KY
2022 Rapid Red 701A
That diagram was pulled from PTS, so I’m surprised to hear that. Or are you saying I’m looking at the wrong diagram?
Also there is a very clean cut off line with the headlamps, so I guess it’s more likely that the high beams aren’t turning on
Jesse-Infotainment
Jesse
2024 F150 Lightning
The high beams are controlled by the HCM and th lin bus. Looking at the pic the lin bus is in the wrong spot
dolsen
KY
2022 Rapid Red 701A
Do you know which one is correct? Here’s the passenger side as well
Ford F-150 Solved - LED projector swap no high beams BFCB34EF-C5A7-4161-BB1C-8A8A47302429
Jesse-Infotainment
Jesse
2024 F150 Lightning
yeAH LOOKS LIKE THE Lin bus is in the wrong spot
Ford F-150 Solved - LED projector swap no high beams 1672449367387
Jesse-Infotainment
Jesse
2024 F150 Lightning
Ford F-150 Solved - LED projector swap no high beams 1672449407610
Ford F-150 Solved - LED projector swap no high beams 1672449419743
