Request VIN Lookup Thread
Mstephens20
Matthew
Clearwater Fl
2021 F150 PB Platinum FX4
This is what yo have showing.
There is a different issue with the BCM that won't allow you to update it now, so you still won't be able to do it.
Ford F-150 Request VIN Lookup Thread imag
Got everything else I could updated.
Is there anyway to get BCM while I have FDRS?
Quiltngirl
Darlene
Lakewood Ca
2021 Ford f150 Lariat
Can I get a VIN lookup? Dealer said he did all updates last week when truck was in the shop.
1FTFW1E59MKE05108
Thank you in advance ?
I would appreciate a lookup.
1st F150 bought two months ago. Latest update kept failing, about 10 times. I did a reset and there are no no more updates so I am curious if everything thing is up to date.
Thanks!
VIN: 1FTEW1EP2MFA63202
The reason that update failed was due to low battery conditions. At this point, the OTA timed out so you'd have to wait for it to be resent to you. This was what the truck reported to the cloud the last time it failed:
"errorCode":"InhibitRequiredHvNotQualifiedLvLow(204)""totalLvBatteryCapacity":"27""currentLvBatteryDataQuality":"OK""currentLvBatteryVoltage":"12""currentLvBatterySoc":"48""currentLvBatteryTemperature":"36""dynamicPostUpdateSocThreshold":"41""estimatedTimeToActivate":"420""estimatedTimeIncludingRollback":"700""currentDrainRate":"9"
Capacity is at 27 of 70 and charge was at 48%. Next time, you need to charge up to the 12v battery to give it a chance to go through.
1FTFW1E59MKE05108
They did not. You are not on the latest Sync version and modules pending updates are below:
Ford F-150 Request VIN Lookup Thread 1716646991654-jh
Rainman77
2021 F150 Platinum
This is my second post here (first was yesterday). Over the past year, this forum has helped me have my dealer replace a stuck APIM, buy a Mongoose, install missing updates, calibrate my speedo for a lift, and fix several problems... Such a great help!
I wonder if I could get an expert's opinion on where I'm at now? Any suggestions?
1FTFW1E89MFA25558
Thank you!
1FTFW1E89MFA25558
Thank you!
Everything looks good. You're getting stead OTA's and are only showing a few minor module updates pending. You're good to go!
Iroga
Igar
Europa
Ford Edge 2019
Hello. Since in my country there is no dealer access to the database, tell me 2FMPK3K99KBB53642
I'm curious how a 2019 Canadian built left-hand drive Edge ends up in Russia. Got to be a rare thing to have a Ford over there.
"Steve"
"Steve"
NTX
21(1).302.PB.157.OX
SW Updates available, please? 1FTFW1ED8MFB55506. tia.
Fox146
Dana
21 limited sold
Hello. If I could get a look at 1FTFW1EDXMFA82039. I’m about to embark on an FDRS tour so just want to see what’s up before I do. Thank you in advance
Update .Im into the fdrs so no need for a check. Thanks
PatchManager
Colorado Springs
Firmware Engineer
Could someone please to see if I have any module updates available? My VIN is 1FTFW1ED7NFC16877.
PRESTON.VICK
Preston
rome ga
manager
So I had my APIM module replaced on 5/22, and I haven't received any OTA updates yet. Before the replace I was on 20262, and after the replacement I'm on update 21146. I'm very aware that that is WAY out of date. but I'm curious when I"ll receive an actual update. I can set auto update, schedule times, all that good stuff. I saw in a previous comment above this that someone checked their vin to make sure the dealer installed everything correctly?? Could someone help me with that also please.
VIN: 1FTFW1E82MFA35915
If I'm right it's a Job 1 truck.
jbruize
2021 F150 XLT
Thank You!
nicholsbradley
Bradley
Louisiana
2021 Ford F150 Platinum
Analyst
Been, a while checking to see if anything new is available. Mainly Blue Cruise updates.
1FTFW1ED0NFA26645
Hersh
Hersh
Ontario
2021 F-150 Lariat
Hello rugedraw,
I’m wondering if you can help me.
I purchased a 2021 F150 in February.
The last update I received was on May 19. It was 22-PU1009-TLC-CSM2. After reading the OTA update history, it says this update was released in January 2024.
Is it common to get these updates months after release? It appears there’s been about a dozen updates since that one. Do I just keep waiting for them to be pushed to me, or is there a reason I haven’t received them yet?
After exploring this forum I replaced the stock battery with an H8, as I was experiencing some low battery charge issues. Those issues went away with the new battery, and I eventually received the aforementioned update.
My VIN is 1FTFW1E51MKD35216
Thanks very much for your time.
I cannot see any info on this vehicle. What I can tell you is that it is on the same SYnc version it was built with in 2019, so for sure there have to be some updates due for it.
