Request VIN Lookup Thread
stocovick
Bruno
Toronto
F-150 Lariat
Hi everyone, I haven't received an update in a long time. Could someone please check my vehicle for me? Thank you very much for your help!
1FTEW1EP2MKE08655
cptn12
Louisiana
2025 F150 Raptor
1FTFW1C58MFB84810 can someone check mine? I was told by Ford that it was downloading last week but still do not have anything on my end.
JIMFOUNTAIN
Jim
Austin, Tx
2021 F150 SCREW PB 6.5' 701A
After nearly 48 hours of running in generator mode (and trailer lights OTA showing up during) I find my shifting has gotten a lot harsher. Many other reporting OTAs have improved their shifting....
I was wondering if I also got a PCM update... Or maybe I just need the trans to relearn after days running but not shifting. If someone can check updates ... much appreciated.
VIN 1FTFW1ED5MFB13052
rugedraw
Javier
Miami
Auto Sales
1FTFW1ED6NFB38947
Looking to see if I have any updates available.
You're on Sync 22294 which is the most recent one. You may have some updates on FDRS, but I don't have my laptop to check. As far as OTA's go, you are good to go.
Could you please check 1FTFW1E83NFA27212 ?
I bought this 2022 with about 9k miles on it. Had no issue getting the BlueCruise update/date sent to it but now hoping desperately to get the fullscreen CarPlay added.
TIA!
3.5.3.2 was sent to you on 2/1 and it failed to install the same day. Error code reported is:
"errorCode":"RANGE_NOT_SATISFIABLE(416)""errorCategory":"HTTP(1347703880)""binaryUrl":"https://mmota-cdn.autonomic.ai/ford/AU_FORD_VADR_PRD-030881c5-d7cc-4e27-a75e-b959c532fb2f""ecuId":"2000"
I have no idea what that means, but this update has failed for many people and I have seen this error code several times recently.
1FTFW1E84MFB62360. Hoping some updates are available.
You are on Sync 22177, so you definitely have updates available. Your last OTA was a TRM update that was sent to you on 1/18. Nothing in your queue right now.
1FTEW1EP2MKE08655
No OTA history in the past 60 days and none in queue right now. Based on your Sync version, you do need updates to be up to date, but your truck is not stuck. You just haven't gotten any love from Ford in a while.
3.5.3 was sent to you on 1/26, and the OTA trigger expired before it was able to download the files. This has happened to many people with this update. You gotta wait for it to be resent to you.
You got 3.5.3 on 1/9, and then two non power up updates this month. However, none was a PCM update. One was a BCM and the other was for the driver and passenger door modules. None of these updates should affect drivability. Looking at your DTC's yesterday, your truck didn't seem to happy running for that long.
Ford F-150 Request VIN Lookup Thread Picture12
stocovick
Bruno
Toronto
F-150 Lariat
Thank you very much for checking! It is too bad that we can't manually force updates.
rugedraw
Javier
Miami
Auto Sales
You can, but the tool needed to do so is $550 and the license from Ford to access their software is another $50 for two days worth of time with their software.
DIY1978Guy
Darren
Louisiana
2021 F150 XLT FX4
1FTFW1E57MFA75784
Can you please check mine? None of the manual workarounds or "tricks" have worked so far. Annoying as hell!
UPDATE: Have the battery charger connected to the truck and its FINALLY UPDATING!!! WOW!!
DPerry918
Tulsa, OK
2022 402A Tremor 🔥
Data Science / Web Engineer
@rugedraw
I think my update failed but can you confirm for me? Would I need to take to dealer since it failed?
1FTEW1E83NFB98179
PlugUgly234
2022 F150 Lariat 3.5L Ecoboost
Firefighter
Looking for OTA updates, Thank You
1FTFW1E85NFA11867
Webbman81
Acworth, GA
2021 F150 King Ranch
Project Executive
Hi! I’ve called Ford numerous times and they say I have an update pending. Can someone check and see what the update is and why it hasn’t been downloaded yet? My vin is 1FTFW1E89MFC84244
Scof
Kelly
Fargo ND
2023 Raptor
Greetings
Any updates OTA/module for my vin
1FTFW1RG8PFA03444
Thanks
rugedraw
Javier
Miami
Auto Sales
1FTFW1E57MFA75784
You have 2.8.1 sitting in your queue ready to install. It has failed several times due to low battery voltage. This update is a big one and requires your truck to be inhibited for over an hour while it installs. It is imperative that you connect a battery charger to your truck and schedule the update to install in the middle of the night after it has been on the charger for a while. This update was sent to you on 2/7 and it will expire on 2/21 if it does not install, and these older updates to not get sent out very often. If you don't have an AGM battery charger, borrow or buy one ASAP if you do not want to wait months for it be sent to you again.
@rugedraw
1FTEW1E83NFB98179
3.5.3.2 was sent to you on 1/27 and it failed the same day. Error is "Group Final Check Failure" which probably means some mismatching software that caused your GWM to reject the update. Nothing you could have done to change the outcome. You gotta wait for it to be resent.
1FTFW1E85NFA11867
No OTA history in the past 60 days and no OTA in queue at this time.
3.5.3 was sent to you on 1/26 and it failed the same day. It was sent to you again and has been stuck trying to download the files since then with no luck. No need to call Ford. The people who answer the phones are fluffers who don't know anything and have no way of helping you. Nothing you can do but hope the OTA gods shine upon and let the update go through before it expires.
rugedraw
Javier
Miami
Auto Sales
Greetings
1FTFW1RG8PFA03444
Thanks
You have a 2023. Your truck should be up to date already.
rugedraw
Javier
Miami
Auto Sales
Any updates for mine,1FTEW1EP9MFD07704,thanks
3.5.3 was sent to you on 1/18, but the OTA trigger expired on 2/1 before it was able to download the files. Same thing that has happened to many others.
