Request VIN Lookup Thread
Walter Townsend
Walter
Nelson, BC, Canada
2021 F150 Lariat FX4 Off Road Fishing Edition 5.0
Owner Operator Starlight Tool Services Ltd Millwright/Welder/Machinist/Electronics tech
Your truck is fine. The update Ford is trying to send you is failing because you already have it. You just need the GWM to be sent to you instead of that APIM update that keeps failing.
Thanks!
rugedraw
Javier
Miami
Auto Sales
Requesting on behalf of someone else,
1FTFW1E51PFB74198
Last OTA it got was 6.4.0 about 3 weeks ago. Nothing to be worried about with this truck, IMO.
rugedraw
Javier
Miami
Auto Sales
Would appreciate any info you can grab on 1FTFW1ED3PFA61988! Just got this 2023 Lariat PB over the weekend. It sat on a dealer’s used lot for over half a year.
Truck is fine. Last successful power-up OTA was 6.4.0. 6.5.0 was sent to it in February but failed because nobody started the truck to allow the OTA trigger to go on to the next step. After that, it got an ACM update a few days ago. 6.5.0 will be resent eventually. Nothing to be worried about here.
rugedraw
Javier
Miami
Auto Sales
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
@rugedraw
Hi
Can you help please and check out if there is any available updates for my truck.
VIN# 1FTFW1E51MFC37912
Thanks in advance
rugedraw
Javier
Miami
Auto Sales
@rugedraw
Hi
Thanks in advance
You're on the latest Sync and nothing showing in FDRS. Good to go.
PullinSleds
Chicago
2021 F150 Lariat Supercrew
@rugedraw
Hi, I haven't seen any update since September, curious what might be on backlog....
Can you help please see if an update is pending or waiting on something?.
VIN# 1FTFW1E82MKE13738
Thanks a ton!
rugedraw
Javier
Miami
Auto Sales
@rugedraw
Thanks a ton!
Nothing has been sent since then. TCU update 4.2.4 was sent to the truck three times and it failed to install all three times. You most likely need that update before you see the 6.x.x updates. Since the OTA dashboard shows it failed multiple times, you may be able to get your dealer to do it for you. It doesn't hurt to try.
Ford F-150 Request VIN Lookup Thread 1709693975663
PullinSleds
Chicago
Thanks so much! I'll give it a try next time im in there. I suppose being armed with this info should help....
Thanks again!
Hullguy
Jim
Weymouth, MA
2013 F150 FX 4
Retired Union Electrician
Looking to see my update status.
1FTFW1ED5MFC97344
Thankd, Jim
