HCFX
Wondering if anyone with the max trailer tow 3/4 floating axle is having the same issues as I am and found a resolution? My driveline is extremely noisy. Doesn't matter if it's when changing between park, drive, reverse or at speed, it's constantly clicking and clacking. So far the dealership has greased the slip yoke on the driveshaft and retorqued the pinion nut, removed the diff cover and backlash is correct, everything inside the rear diff looks a-ok. Outer axle hub bolts are intact and at the proper torque. At my wit's end with this! It's pretty embarrassing when you're camping with your buddies, none of whom own a truck with less than 150k, and they're standing around asking you what the hell's wrong with your 1yr old low mileage pickup while you're maneuvering your camper and it's snapping and clicking to no end.
2023 5.0L 3.73 ELD w/Max Tow. 11,000 miles.
