Skier167
Nate
2021 f150
Thanks for the warning. I as well had 75% of my fuses were not seated all the way including some larger ones.
Smitdog
2021 F150 Limited PowerBoost Smoked Quartz
Gainfully Retired
Well, I pressed on all fuses under the hood and also near the passenger interior footwell. Most were able to be pushed in ever so slightly, but I seriously doubt any of them were actually "unseated".
Either way, my dash settings will still occasionally "reset", and I'll have to redo the My View and gauge configuration settings.
JimL
Jim
SW PA
2019 Bullitt, 2020 F-150
Babylon 5 security
For $50,000-$60,000-$70,000, you’d think they could make sure these little buggers were properly seated. What the hell Ford?
Oly80498
Eric
Summit County, CO
2021 F150 PB Lariat
yup - most of mine needed a push/click. Radio and Apple Car Play have been rebooting/shutting down, so hopefully this will help.
150ish
Scott
2021 Ford F150
Inspector Gadget
Almost every single fuse and all relays were out by almost 1/8"
Now I'll wait and see if any of my issues go away. I really want the complete loss of power while turning right to go away before I end up getting T-Boned.
150ish
Scott
2021 Ford F150
Inspector Gadget
I think those issues are caused by outside forces. My CarPlay disconnects and automatically shuts down my radio in the same exact spot of my commute every day. I found that if I quickly turn the radio back on it stands a better chance of reconnecting to the phone.
fmdog44
steve
2012 F150 XL
Sounds like either the procedure for installing the fuses needs a review or the design of the "fit" is not correct so it you had an issue you may want to check every so often.
Ed21
Ed
Illinois
2021 F150 Xlt SCREW
Mine are all tight as a ducks arse.
MattM
Matt
Seattle
2021 Powerboost Platinum FX4
Same with mine. Thanks for the head's up.
xtraman122
Pete
MA
‘24 303A PB
I checked mine, they almost all pushed in just a bit, but I don’t necessarily think any felt like they were actually about to fall out or anything like that.
jeffcrum
Lake Saint Louis, MO
Computer programmer
I have never checked that before. But, depending on the duck, you might need to push in. Just saying.
PB2021
Rob
2021 F150 Lariat Powerboost
Thanks for the info. Just checked engine bay fuses and found about 50% that could be pushed in a little further. I don't believe any were even close to losing contact though. In contrast all were very firmly seated in the passenger foot well fuse block. Could underhood temps be causing a little shifting I wonder?
xXChartmanXx
San Diego, CA
2011 Explorer, 2021 VW ID.4, 2021 F150 Lariat
CyberSecurity Engineer
All of mine seemed to be seated just fine. Worth the check though.
texag
CA
2010 Silverado
Checked mine as well. The smaller ones seemed to go in further. Not a ton of movement but they certainly went in a bit further.
