Oil changes with these trucks seem amazingly easy
Hans Moleman
SF Bay
I’m used to Toyota trucks where you have remove skid plates and clean the oil filter canister because they use an filter element. Oil also drips everywhere like the steering rack so I have to spend extra time cleaning.
With my F-150 I just did the 2nd oil change myself and it was extremely easy. No need to remove any skid plates. The oil filter area has a catch tray which drains oil thru a hole in the skid plate. I just spray down the catch tray with brake cleaner and no need for any additional cleaning. It uses a regular oil filter so no need to clean any canisters.
TheGoatman
22 powerboost
I’ve had GM v8s.
drain plug and filter right next to each other. No sway bar, no pans, nothing.
can go under once to pull plug and filter and then back in to replace and done. The filter is upright so you can pre fill. Very possible to not drip a drop.
js312
Joe
New England
2023 Lariat PowerBoost
IT Director
The 2.7 with the top filter is nice.
The 3.5s filter placement is miserable. On my 2020 it was bad, on my 2023 it is in the same spot but there is more other stuff in the way now, so it's even worse.
No experience with the 5.0.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
it is, it’s also easier if you install a Volvo Max oil drain. I can do an oil change and use one shop towel.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
it certainly is buried in there a little bit, but I’ve had zero issues with it. I can get on it with a filter wrench & ratchet, no other tools.
Tony 70
Anthony
mC405!-wdF
2009 Mustang Bullitt 2023 Tacoma
I change my own oil, don't trust the dealership.
Any issues with the warranty, changing your own oil ?
2024 powerboost
hatallica
W. PA
2024 KR
Did my first change (PB 3.5L) about a week ago, and it was generally painless.
Fumoto F107N drain valve installed, so the next change will be even easier.
Motivx MX2374 oil filter wrench was a treat for gripping the original filter. Not required, but I chose to use a swivel-head ratchet. Lots of threads with lots of clever tools for this step.
My only issues were being sloppy. First, underestimating how far the oil would shoot out after removing the drain plug (solved with Fumoto). Second, forgetting that the oil filter drain tray will send oil in the opposite direction of what I anticipate.
  • Like
Reactions: kd-
hatallica
W. PA
2024 KR
Generally, no issue. The onus is on Ford to demonstrate that an issue was caused by your use of improper materials or technique.
The ability to document DIY maintenance in the service history is a nice touch.
js312
Joe
New England
IT Director
This is the first vehicle I felt I needed a filter socket for. With that, it isn't too bad. Without, I had a hard time getting leverage to remove the filter.
Mt.F150..
Kevin
California
24' f150 xlt supercrew 4x4 5.0
The 2.7 and 5.0 oil changes are relatively easy, but nothing compares to oil changes in a jeep wrangler with the 3.6 filter is on top like the 2.7 and no sway bars or skid plates to deal with
Aonarch
North GA / MT
'24 V8 XLT 302a BAP, Tow | '22 Mustang Mach 1 | '25 Wrangler JLUR
Motorsport Engineer
5.0 is easy. There is a built in plastic funnel for the oil filter so oil doesn't get everywhere.
Hans Moleman
Hans Moleman
SF Bay
Yeah it looks bad. However when I did the actual job it was surprisingly easy. I used a Lisle 61570 cap wrench with a wobble extension to loosen the oil filter. After I removed the oil filter from the mount, I tilted it to drain most of the oil into the catch tray before fully removing from underneath without dripping any oil on anything.
