My PowerBoost is essentially dead
devern
Devern
Eastern Charlotte, NB, Canada
2021 F-150 Lariat 502A PowerBoost
DevOps
Just to add some data after staring at this again for a while... 12.37V measured during the freeze frame seems low to me.
Trouble Code Report
ECUCodeTypeStatusUDS StatusDescription
Battery Energy Control ModuleP1A42-00PowerTrainConfirmedDTC is confirmed at the time of the request
DTC test failed at least once since last code clear
ECU is requesting the warning indicator to be active
Propulsion System Status Signal Performance
BECM-B+EnergyCtrlP1A42PowerTrainConfirmedN/APropulsion System Status Signal Performance
BECM-B+EnergyCtrlP1A42PowerTrainPermanentN/APropulsion System Status Signal Performance
DC to DC Converter Control ModuleU0100-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With (ECM)/(PCM) 'A'
DC to DC Converter Control ModuleU0293-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With Hybrid Powertrain Control Module
Gateway Module AU0001-09NetworkConfirmedDTC is confirmed at the time of the requestHigh Speed (CAN) Communication Bus
Power Steering Control ModuleU0415-00NetworkConfirmedDTC is confirmed at the time of the request
Invalid Data Received from Anti-Lock Brake System ((ABS)) Control Module 'A'
Mode $02 - Freeze Frame
First Occurrence
DescriptionValueUnits
Freeze frame DTCP1A42
Calculated load value0%
Engine coolant temperature-40°C
Engine RPM16383.75RPM
Vehicle speed255km/h
Time since engine start0sec
Control module voltage12.37V
Accelerator pedal position D0%
Different items on different busses? GWM issue?
The gateway module is rather important providing communication between each of the discrete busses. Think of it like an ethernet switch that instead of talking to each computer, it talks to a bus that has half a dozen 'computers' on each one. The fact the GWM is showing up in there as well as different items on different busses seems to point at it specifically.....
Ford F-150 My PowerBoost is essentially dead 1685495337081
That dang module is so mission critical to the whole truck assembly. Does make you wonder considering it gets so many updates and a "software bug" there could have you chasing rabbits so easily.
devern
Devern
DevOps
The situation at the moment of the frame was attempting to start the truck after work. This is why I think the PCM isn't being woken up, and the other modules read a default value of max, or 0xFF or what have you.
They have apparently replaced the GWM already last year. It threw more codes from additional modules that last time this happened (April 15). I didn't think to store a diag report, but got some screenshots while it was happening. Common theme might be the 12V voltage?
Ford F-150 My PowerBoost is essentially dead 1685495546562
Ford F-150 My PowerBoost is essentially dead 1685495561921
Ford F-150 My PowerBoost is essentially dead 1685495579003
Ford F-150 My PowerBoost is essentially dead 1685495621193
devern
Devern
DevOps
One other thing that has me curious... I've been stuck on 1.7.1 OTA for a while too. I have to wonder which module is causing that, and could it be contributing to *whatever* is causing this behaviour?
Wait.
Have you had anyone look up your VIN in FDRS?
Ford, as much flack as we give them for their software code, has updated so much on so many aspects of the Gen14 truck since that "era"
devern
Devern
DevOps
Apologies for the wall of text, I'm brainstorming in this post a bit.
SO another nice weekend parked in the sun and we get stranded. Thankfully, for whatever reason, we seem to be able to turn on some accessories (Air Conditioning) when it exhibits "Stop Safely Now" / "No start" conditions.
Lots more codes this time though, surprisingly. It seems like the actions taken by my dealer's service dept are altering the symptoms, so it's likely there were/are multiple deficiencies. One new permanent code that led me to look at a couple of published bulletins: P1A0E "Hybrid Powertrain Control Module - Motor Disabled". The 12V system is still suspect, based on data I was able to record while experiencing the problem. Multiple modules were reporting voltages under 12V: I was able to observe the IPC Module @ 11.6V, BECM Battery Voltage @ 11.9V, APIM @ 11.9V, Occupant Classification System Module @ 11.8V. I could not read the PCM or ABS modules' voltage, since there was no communication. This was after ~1 hour of highway driving, and then parked with both FOBs out of range of the truck for ~2 hours. After about 30 minutes, I was able to start the truck again. The only actions I took were to pop the hood and wiggle several points in the harness while watching multiple PIDs for module voltage fluctuations (there weren't any). Finally, I closed the hood and the driver's seat adjusted to the stored position. Whether that is coincidence, or the impact from closing the hood jostled *something*... who knows. I then attempted to start the truck from the FordPass app, and it was able to start on the second attempt (the first attempt had the driver's door open). Now, this is the first time that I've seen the truck display "Stop Safely Now" after a successful start. So I let the truck idle for a bit, very hesitant to attempt moving it. Stopping and starting a second time after idling for a few minutes, the IPC warnings were no longer present, so we drove home.
Now, watching those same PIDs directly after successfully starting the truck, they all read in the range of 14V (the DC-to-DC inverter actively charging the 12V system). Observing them again today, their "steady state" voltage appears to be around 12.8V.
I'll be having a rather lengthy chat with the service dept tomorrow. The code it stored yesterday allowed me to find a couple of potentially relevant bulletins: TSB 21-2072, and SSM50151. When I examined the wiring diagrams a couple of months back, I suspected a MOSFET on the BCM that sends wake signal to the BECM, SOBDMC and PCM. I think I was on the right track, but I also observed the PID for this Wake signal changing from position 2 to position 1 (MOSFET most likely is good) when attempting to start the vehicle. Now, TSB-21-2072 provides a key piece of information: "(SOBDMC), also referred to as the inverter system controller (ISC).".
I wonder... what if:
  • there is a problem with the SOBDMC, or an attached module that it depends on
    • could this impact the DC-to-DC conversion, preventing the hybrid battery from providing conditioning of the 12V system?
    • how could this be linked to warm weather / a hot cabin
  • there is a problem with the aux 12V battery, causing a rapid drain on the 12V system
    • there is no temperature monitoring on it, and there is no separate isolated voltage readout. it is located in the cabin, so potentially a poor connection, or failing battery could be adversely impacted by heat?
    • could it cause the PCM and other modules to fail to wake due to lower voltage? Not outside the realm of possibilty IMO; the PCM has previously stored codes about low voltage, and failed self-tests.
At any rate, I expect the plethora of communication failures are a symptom, rather than a cause. Now, conveying this to my service advisor in a way that makes sense and might actually be helpful... well that will be the next struggle :LOL:
I didn't think to generate the fancy HTML report while it was happening, unfortunately. But all of the codes were present until after I drove the vehicle today. Now the permanent code is gone and MIL indicator is off. :unsure:
Trouble Code Report
Air Conditioning Control ModuleU0100-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With (ECM)/(PCM) 'A'
All Terrain Control ModuleU0102-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication with (TCCM)
Anti-Lock Brake / Traction Control ModuleU0100-00NetworkConfirmedDTC is confirmed at the time of the request
Anti-Lock Brake / Traction Control ModuleU0103-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With (GSM)
Anti-Lock Brake / Traction Control ModuleU1026-00NetworkConfirmedDTC is confirmed at the time of the request
(ABS) Control Module Lost Communication with Hybrid/(EV) Powertrain Control Module
Body Control ModuleU023A-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication with Image Processing Module A
Body Control ModuleU0121-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Anti-Lock Brake System ((ABS)) Control Module 'A'
Body Control ModuleU0131-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Power Steering Control Module 'A'
Body Control Module CU0100-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With (ECM)/(PCM) 'A'
Body Control Module CU0121-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Anti-Lock Brake System ((ABS)) Control Module 'A'
Body Control Module CU0293-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Hybrid Powertrain Control Module
Driver Front Door ModuleU0232-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Side Obstacle Detection Control Module 'A'
Gear Shift ModuleU0100-00NetworkConfirmedDTC is pending at the time of the request
Gear Shift ModuleU0100-00NetworkPendingDTC is pending at the time of the request
Gear Shift ModuleU0121-00NetworkConfirmedDTC is pending at the time of the request
Gear Shift ModuleU0121-00NetworkPendingDTC is pending at the time of the request
Gear Shift ModuleU0100-87NetworkConfirmedDTC is pending at the time of the request
Gear Shift ModuleU0100-87NetworkPendingDTC is pending at the time of the request
Headlamp Control ModuleU0121-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Anti-Lock Brake System ((ABS)) Control Module 'A'
Headlamp Control ModuleU0126-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Steering Angle Sensor Module
Headlamp Control ModuleU0146-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Gateway A
Headlamp Control ModuleU023A-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication with Image Processing Module A
Image Processing Module AU0100-00NetworkConfirmedDTC is confirmed at the time of the request
Image Processing Module AU0101-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication with (TCM)
Image Processing Module AU0103-00NetworkConfirmedDTC is confirmed at the time of the request
Image Processing Module AU0121-00NetworkConfirmedDTC is confirmed at the time of the request
Image Processing Module AU0131-00NetworkConfirmedDTC is confirmed at the time of the request
Image Processing Module AU0140-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With Body Control Module
Image Processing Module AU0151-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With Restraints Control Module
Image Processing Module AU0155-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With Instrument Panel Cluster ((IPC)) Control Module
Image Processing Module AU0212-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With (SCCM)
Image Processing Module AU0253-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With Accessory Protocol Interface Module
Image Processing Module AU0401-86NetworkConfirmedDTC is confirmed at the time of the request
Invalid Data Received from (ECM)/(PCM) A
Image Processing Module AU0402-86NetworkConfirmedDTC is confirmed at the time of the request
Invalid Data Received From (TCM)
Image Processing Module AU2300-55NetworkConfirmedDTC is confirmed at the time of the request
Central Configuration
Image Processing Module AU0200-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With Door Control Module B
Image Processing Module AU0424-86NetworkConfirmedDTC is confirmed at the time of the request
Invalid Data Received From (HVAC) Control Module - Rear
Image Processing Module AU0164-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With (HVAC) Control Module
Instrument Panel Control ModuleU0100-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With (ECM)/(PCM) 'A'
Instrument Panel Control ModuleU0232-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Side Obstacle Detection Control Module 'A'
Instrument Panel Control ModuleU0233-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Side Obstacle Detection Control Module 'B'
Instrument Panel Control ModuleU0401-82NetworkConfirmedDTC is confirmed at the time of the requestInvalid Data Received from (ECM)/(PCM) A
Occupant Classification System ModuleU0100-00NetworkConfirmedDTC is confirmed at the time of the request
Pedestrian Alert Control ModuleU0100-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With (ECM)/(PCM) 'A'
Power Steering Control ModuleU0100-00NetworkConfirmedDTC is confirmed at the time of the request
Power Steering Control ModuleU0121-00NetworkConfirmedDTC is confirmed at the time of the request
Power Steering Control ModuleU3003-68NetworkConfirmedDTC is confirmed at the time of the request
Battery Voltage
Radio Transceiver ModuleU0401-00NetworkConfirmedDTC is confirmed at the time of the request
Radio Transceiver ModuleU0401-82NetworkConfirmedDTC is confirmed at the time of the request
Rear Gate Trunk ModuleU0101-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication with (TCM)
Rear Gate Trunk ModuleU0121-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Anti-Lock Brake System ((ABS)) Control Module 'A'
Restraint Control ModuleB00A0-68BodyConfirmedDTC is confirmed at the time of the requestOccupant Classification System
Restraint Control ModuleU0100-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With (ECM)/(PCM) 'A'
Restraint Control ModuleU0401-81NetworkConfirmedDTC is confirmed at the time of the requestInvalid Data Received from (ECM)/(PCM) A
Restraint Control ModuleU0422-92NetworkConfirmedDTC is confirmed at the time of the requestInvalid Data Received From Body Control Module
Restraint Control ModuleU0121-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Anti-Lock Brake System ((ABS)) Control Module 'A'
Restraint Control ModuleU023B-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Image Processing Module B
Restraint Control ModuleU0131-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Power Steering Control Module 'A'
Secondary OBD Control Module CP0A23-00PowerTrainConfirmedDTC is confirmed at the time of the request
Generator Torque Sensor Circuit Range/Performance
Secondary OBD Control Module CP0A2F-94PowerTrainConfirmedDTC is confirmed at the time of the request
Drive Motor A Over Temperature
Secondary OBD Control Module CP1A0E-64PowerTrainConfirmedDTC is confirmed at the time of the request
Secondary OBD Control Module CP1A0E-96PowerTrainConfirmedDTC is confirmed at the time of the request
Secondary OBD Control Module CU0100-00NetworkConfirmedDTC is confirmed at the time of the request
Secondary OBD Control Module CU0111-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With Battery Energy Control Module 'A'
Secondary OBD Control Module CU0140-00NetworkConfirmedDTC is confirmed at the time of the request
Secondary OBD Control Module CU0151-00NetworkConfirmedDTC is confirmed at the time of the request
Secondary OBD Control Module CU0155-00NetworkConfirmedDTC is confirmed at the time of the request
Secondary OBD Control Module CU0164-00NetworkConfirmedDTC is confirmed at the time of the request
Secondary OBD Control Module CU0298-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With (DC/DC) Converter Control Module 'A'
Secondary OBD Control Module CU1022-00NetworkConfirmedDTC is confirmed at the time of the request
Invalid Internal Control Module Monitoring Data Received from Body Control Module
HPCM-HybridPtCtrlP0A23PowerTrainConfirmedN/AGenerator Torque Sensor Circuit Range/Performance
HPCM-HybridPtCtrlP1A0EPowerTrainConfirmedN/AHybrid Powertrain Control Module - Motor Disabled
HPCM-HybridPtCtrlU0100NetworkConfirmedN/ALost Communication With (ECM)/(PCM) 'A'
HPCM-HybridPtCtrlU0111NetworkConfirmedN/ALost Communication With Battery Energy Control Module 'A'
Trailer ModuleU0100-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With (ECM)/(PCM) 'A'
Trailer ModuleU0121-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Anti-Lock Brake System ((ABS)) Control Module 'A'
Trailer ModuleU0140-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Body Control Module
Trailer ModuleU0131-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Power Steering Control Module 'A'
Transfer Case Control ModuleU0100-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With (ECM)/(PCM) 'A'
Transfer Case Control ModuleU0101-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication with (TCM)
Transfer Case Control ModuleU0121-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With Anti-Lock Brake System ((ABS)) Control Module 'A'
Additional Information
Malfunction indicator lamp (MIL) statusOff
Freeze frame DTCU0111
Distance traveled while MIL is activated0km
Number of warm-ups since DTCs cleared6
Distance traveled since DTCs cleared676km
First Occurrence
I/M Readiness DataMIL Off, # Trouble Codes 0 Misfire: Not Available Fuel System: Not Available Comprehensive Component: Complete Catalyst: Not Available Heated Catalyst: Not Available Evap System: Not Available Secondary Air System: Not Available Gasoline Particulate Filter: Not Available Oxygen Sensor: Not Available Oxygen Sensor Heater: Not Available EGR and/or VVT System: Not Available
Engine coolant temperature57°C
Engine RPM0RPM
Number of warm-ups since DTCs cleared5
Distance traveled since DTCs cleared440km
Control module voltage12.34V
Accelerator pedal position D16.08%
I suspect a "Service Advisor" will have their eyes glaze over if a well informed/researched customer attempts to educate him/her.
And even worse, getting that same information to the mechanic/technician that will eventually pull your ticket 4 days later?
It's a lousy scenario these days.
If/when I am ever confronted with this alert, I will make every effort to diagnose, but more importantly, look for a work around to get the truck operational so I can get where I'm going.
devern
Devern
DevOps
Just went to check on it again after driving it for 3 hours earlier, and parking it in the sun in my driveway. It's happening again now, but not coming out of it. Significantly hotter today than yesterday. Also, I noticed the touch screen is uncomfortably hot to touch... I wonder if that could somehow be the silver bullet tying everything together. A short or something behind the screen when it's hot out.
One other interesting observation is that "Cannot recall memory position while driving" pops up incessantly. I wonder if the BCM is actually repeatedly attempting to recall the seat position, or if the message is popping up for another reason.
I think I'll need a GWM breakout box to be able to diagnose this further. It's terribly difficult getting info while it's happening when the GWM can't communicate with so many modules. At least it seems to be getting more easily repeatable now.
My service advisor knows my analytical reputation by now, and recently introduced me to their head electrical guy. We talked shop for a bit last time I was there, so I might be fortunate enough to get his ear again directly and hopefully fill in some blanks.
devern
Devern
DevOps
I just noticed the SOBDMC recorded P0A2F-94 "Drive Motor A Over Temperature". I'm treating anything that doesn't fall under communications issues as even more suspicious. This also has related TSBs that call for reprogramming of modules to fix... ?
Would be great if I could nail down a root cause. If I get to a point where I'm confident that this is something I can solve with a mongoose and FDRS... well, that might just be the justification I have been wanting for the past year. Can't let my confirmation bias distract from troubleshooting though
devern
Devern
DevOps
Walked away from it for a while and now of course it starts right up. 198 codes stored now. Some more new P codes that also look troubling.
Between P0562-00 "System Voltage Low" stored in the PCM, and P1A0E, P0A23, P0A71, P0A74, P0A77 and P06B1 being present in the SOBDMC, I think I can confidently say that SSM50151 to troubleshoot the 12V system is the dealer's next course.
Ford F-150 My PowerBoost is essentially dead 1686519029922
Trouble Code Report
Battery Energy Control ModuleU0293-00NetworkPendingDTC is pending at the time of the request
Battery Energy Control ModuleU0100-00NetworkPendingDTC is pending at the time of the request
Battery Energy Control ModuleP1A43-00PowerTrainPendingDTC is pending at the time of the request
Hybrid/(EV) Battery Contactor Request Signal Performance
Battery Energy Control ModuleP1A42-00PowerTrainConfirmedDTC is pending at the time of the request
Battery Energy Control ModuleP1A42-00PowerTrainPendingDTC is pending at the time of the request
BECM-B+EnergyCtrlU0293NetworkPendingN/ALost Communication With Hybrid Powertrain Control Module
BECM-B+EnergyCtrlU0100NetworkPendingN/ALost Communication With (ECM)/(PCM) 'A'
BECM-B+EnergyCtrlP1A43PowerTrainPendingN/AHybrid/(EV) Battery Contactor Request Signal Performance
BECM-B+EnergyCtrlP1A42PowerTrainPendingN/APropulsion System Status Signal Performance
Body Control ModuleU0100-87NetworkConfirmedDTC is confirmed at the time of the requestLost Communication With (ECM)/(PCM) 'A'
Gear Shift ModuleU0100-87NetworkConfirmedDTC is confirmed at the time of the request
Image Processing Module AU0100-00NetworkConfirmedDTC is pending at the time of the request
Image Processing Module AU0100-00NetworkPendingDTC is pending at the time of the request
Image Processing Module AU0101-00NetworkConfirmedDTC is pending at the time of the request
Image Processing Module AU0101-00NetworkPendingDTC is pending at the time of the request
Image Processing Module AU0121-00NetworkConfirmedDTC is pending at the time of the request
Image Processing Module AU0121-00NetworkPendingDTC is pending at the time of the request
Image Processing Module AU0140-00NetworkConfirmedDTC is pending at the time of the request
Image Processing Module AU0140-00NetworkPendingDTC is pending at the time of the request
Image Processing Module AU0253-00NetworkConfirmedDTC is pending at the time of the request
Image Processing Module AU0253-00NetworkPendingDTC is pending at the time of the request
Image Processing Module AU0401-86NetworkConfirmedDTC is pending at the time of the request
Image Processing Module AU0401-86NetworkPendingDTC is pending at the time of the request
Image Processing Module AU0402-86NetworkConfirmedDTC is pending at the time of the request
Image Processing Module AU0402-86NetworkPendingDTC is pending at the time of the request
Image Processing Module AU0199-00NetworkConfirmedDTC is pending at the time of the request
Lost Communication With Door Control Module A
Image Processing Module AU0199-00NetworkPendingDTC is pending at the time of the request
Image Processing Module AU0200-00NetworkConfirmedDTC is pending at the time of the request
Image Processing Module AU0200-00NetworkPendingDTC is pending at the time of the request
Image Processing Module AU0424-86NetworkConfirmedDTC is pending at the time of the request
Image Processing Module AU0424-86NetworkPendingDTC is pending at the time of the request
Image Processing Module AU0164-00NetworkConfirmedDTC is pending at the time of the request
Image Processing Module AU0164-00NetworkPendingDTC is pending at the time of the request
Battery Voltage
Powertrain Control ModuleP0230-00PowerTrainPendingDTC test failed on the current operation cycle
Fuel Pump Primary Circuit
Powertrain Control ModuleP0230-00PowerTrainCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleP0562-00PowerTrainConfirmedDTC test failed on the current operation cycle
System Voltage Low
Powertrain Control ModuleP0562-00PowerTrainPendingDTC test failed on the current operation cycle
System Voltage Low
Powertrain Control ModuleP0562-00PowerTrainCurrentDTC test failed on the current operation cycle
System Voltage Low
Powertrain Control ModuleP0600-00PowerTrainPendingDTC test failed on the current operation cycle
Serial Communication Link
Powertrain Control ModuleP0600-00PowerTrainCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleP0607-00PowerTrainPendingDTC test failed on the current operation cycle
Control Module Performance
Powertrain Control ModuleP0607-00PowerTrainCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleP25B0-00PowerTrainPendingDTC test failed on the current operation cycle
Fuel Level Sensor A Stuck
Powertrain Control ModuleP25B0-00PowerTrainCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleP2ABC-00PowerTrainPendingDTC test failed at the time of DTC request
Wastegate Position Sensor 'B' Circuit High
Powertrain Control ModuleP2ABC-00PowerTrainCurrentDTC test failed at the time of DTC request
Powertrain Control ModuleU0103-00NetworkConfirmedDTC test failed on the current operation cycle
Powertrain Control ModuleU0103-00NetworkPendingDTC test failed on the current operation cycle
Powertrain Control ModuleU0103-00NetworkCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleU0111-00NetworkPendingDTC test failed on the current operation cycle
Powertrain Control ModuleU0111-00NetworkCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleU0121-00NetworkConfirmedDTC test failed on the current operation cycle
Powertrain Control ModuleU0121-00NetworkPendingDTC test failed on the current operation cycle
Powertrain Control ModuleU0121-00NetworkCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleU0140-00NetworkConfirmedDTC test failed on the current operation cycle
Powertrain Control ModuleU0140-00NetworkPendingDTC test failed on the current operation cycle
Powertrain Control ModuleU0140-00NetworkCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleU0155-00NetworkConfirmedDTC test failed on the current operation cycle
Powertrain Control ModuleU0155-00NetworkPendingDTC test failed on the current operation cycle
Powertrain Control ModuleU0155-00NetworkCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleU0164-00NetworkConfirmedDTC test failed on the current operation cycle
Powertrain Control ModuleU0164-00NetworkPendingDTC test failed on the current operation cycle
Powertrain Control ModuleU0164-00NetworkCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleU0212-00NetworkConfirmedDTC test failed on the current operation cycle
Powertrain Control ModuleU0212-00NetworkPendingDTC test failed on the current operation cycle
Powertrain Control ModuleU0212-00NetworkCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleU023A-00NetworkConfirmedDTC test failed on the current operation cycle
Powertrain Control ModuleU023A-00NetworkPendingDTC test failed on the current operation cycle
Powertrain Control ModuleU023A-00NetworkCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleU0253-00NetworkConfirmedDTC test failed on the current operation cycle
Powertrain Control ModuleU0253-00NetworkPendingDTC test failed on the current operation cycle
Powertrain Control ModuleU0253-00NetworkCurrentDTC test failed on the current operation cycle
Powertrain Control ModuleU1012-00NetworkPendingDTC test failed on the current operation cycle
Invalid Internal Control Module Monitoring Data Received from Anti-Lock Brake System ((ABS)) Control Module
Powertrain Control ModuleU1012-00NetworkCurrentDTC test failed on the current operation cycle
PCM-PowertrainCtrlP0230PowerTrainPendingN/AFuel Pump Primary Circuit
PCM-PowertrainCtrlP0600PowerTrainPendingN/ASerial Communication Link
PCM-PowertrainCtrlP0607PowerTrainPendingN/AControl Module Performance
PCM-PowertrainCtrlP25B0PowerTrainPendingN/AFuel Level Sensor A Stuck
PCM-PowertrainCtrlP2ABCPowerTrainPendingN/AWastegate Position Sensor 'B' Circuit High
PCM-PowertrainCtrlU0111NetworkPendingN/ALost Communication With Battery Energy Control Module 'A'
PCM-PowertrainCtrlU1012NetworkPendingN/AInvalid Internal Control Module Monitoring Data Received from Anti-Lock Brake System ((ABS)) Control Module
Radio Transceiver ModuleU0401-00NetworkConfirmedDTC is pending at the time of the request
Radio Transceiver ModuleU0401-00NetworkPendingDTC is pending at the time of the request
Radio Transceiver ModuleU0401-82NetworkConfirmedDTC is pending at the time of the request
Radio Transceiver ModuleU0401-82NetworkPendingDTC is pending at the time of the request
Secondary OBD Control Module CP06B1-00PowerTrainConfirmedDTC is confirmed at the time of the request
Sensor Power Supply A Circuit Low
Secondary OBD Control Module CP0A71-00PowerTrainConfirmedDTC is confirmed at the time of the request
Generator Phase U Current High
Secondary OBD Control Module CP0A74-00PowerTrainConfirmedDTC is confirmed at the time of the request
Generator Phase V Current High
Secondary OBD Control Module CP0A77-00PowerTrainConfirmedDTC is confirmed at the time of the request
Generator Phase W Current High
Secondary OBD Control Module CP1A0E-61PowerTrainConfirmedDTC is pending at the time of the request
Secondary OBD Control Module CP1A0E-61PowerTrainPendingDTC is pending at the time of the request
Secondary OBD Control Module CP1A0E-64PowerTrainConfirmedDTC is pending at the time of the request
Secondary OBD Control Module CP1A0E-64PowerTrainPendingDTC is pending at the time of the request
Secondary OBD Control Module CP1A0E-96PowerTrainConfirmedDTC is pending at the time of the request
Secondary OBD Control Module CP1A0E-96PowerTrainPendingDTC is pending at the time of the request
Secondary OBD Control Module CU010F-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With Air Conditioning Control Module
Secondary OBD Control Module CU0121-00NetworkConfirmedDTC is confirmed at the time of the request
Secondary OBD Control Module CU0143-00NetworkConfirmedDTC is confirmed at the time of the request
Lost Communication With Body Control Module C
Secondary OBD Control Module CU1011-86NetworkConfirmedDTC is pending at the time of the request
Invalid Internal Control Module Monitoring Data Received from (ECM)/(PCM)
Secondary OBD Control Module CU1011-86NetworkPendingDTC is pending at the time of the request
Secondary OBD Control Module CU1012-86NetworkConfirmedDTC is pending at the time of the request
Secondary OBD Control Module CU1012-86NetworkPendingDTC is pending at the time of the request
Secondary OBD Control Module CU1022-00NetworkConfirmedDTC is pending at the time of the request
Secondary OBD Control Module CU1022-00NetworkPendingDTC is pending at the time of the request
HPCM-HybridPtCtrlP06B1PowerTrainConfirmedN/ASensor Power Supply A Circuit Low
HPCM-HybridPtCtrlP0A71PowerTrainConfirmedN/AGenerator Phase U Current High
HPCM-HybridPtCtrlP0A74PowerTrainConfirmedN/AGenerator Phase V Current High
HPCM-HybridPtCtrlP0A77PowerTrainConfirmedN/AGenerator Phase W Current High
HPCM-HybridPtCtrlU010FNetworkConfirmedN/ALost Communication With Air Conditioning Control Module
HPCM-HybridPtCtrlU0121NetworkConfirmedN/ALost Communication With Anti-Lock Brake System ((ABS)) Control Module 'A'
HPCM-HybridPtCtrlU0143NetworkConfirmedN/ALost Communication With Body Control Module C
HPCM-HybridPtCtrlU1011NetworkConfirmedN/AInvalid Internal Control Module Monitoring Data Received from (ECM)/(PCM)
HPCM-HybridPtCtrlU1012NetworkConfirmedN/AInvalid Internal Control Module Monitoring Data Received from Anti-Lock Brake System ((ABS)) Control Module
HPCM-HybridPtCtrlP1A0EPowerTrainPendingN/AHybrid Powertrain Control Module - Motor Disabled
HPCM-HybridPtCtrlU1011NetworkPendingN/AInvalid Internal Control Module Monitoring Data Received from (ECM)/(PCM)
HPCM-HybridPtCtrlU1012NetworkPendingN/AInvalid Internal Control Module Monitoring Data Received from Anti-Lock Brake System ((ABS)) Control Module
HPCM-HybridPtCtrlP06B1PowerTrainPermanentN/ASensor Power Supply A Circuit Low
HPCM-HybridPtCtrlP0A23PowerTrainPermanentN/AGenerator Torque Sensor Circuit Range/Performance
HPCM-HybridPtCtrlP0A71PowerTrainPermanentN/AGenerator Phase U Current High
HPCM-HybridPtCtrlP0A74PowerTrainPermanentN/AGenerator Phase V Current High
HPCM-HybridPtCtrlP0A77PowerTrainPermanentN/AGenerator Phase W Current High
HPCM-HybridPtCtrlP1A0EPowerTrainPermanentN/AHybrid Powertrain Control Module - Motor Disabled
HPCM-HybridPtCtrlU010FNetworkPermanentN/ALost Communication With Air Conditioning Control Module
HPCM-HybridPtCtrlU0111NetworkPermanentN/ALost Communication With Battery Energy Control Module 'A'
HPCM-HybridPtCtrlU0143NetworkPermanentN/ALost Communication With Body Control Module C
HPCM-HybridPtCtrlU1011NetworkPermanentN/AInvalid Internal Control Module Monitoring Data Received from (ECM)/(PCM)
HPCM-HybridPtCtrlU1012NetworkPermanentN/AInvalid Internal Control Module Monitoring Data Received from Anti-Lock Brake System ((ABS)) Control Module
Steering Column Control ModuleU023A-08NetworkConfirmedDTC is confirmed at the time of the request
Transfer Case Control ModuleU0138-00NetworkConfirmedDTC is confirmed at the time of the requestLost Communication with All Terrain Control Module
devern
Devern
DevOps
I still think there are 2 separate problems, however, I am starting to lean further into that both of them could be fixed by getting this thing up to date.
I *think* that the codes for "Drive Motor A Over Temperature" and "Hybrid Powertrain Control Module - Motor Disabled" are very much related. I think this is what is causing the brunt of my frustration, and what is ultimately resulting in the no-start condition.
Now, the piece I haven't confirmed yet, but I suspect that some part of the hybrid cooling system is impacted by a 12V drop, so on warm days when the system would require more cooling during operation, the hybrid components are not getting it. It's also possible that a temperature threshold parameter for this was addressed in a software update, and the overtemp condition contributes to the 12V drop somehow.
One thing that bothers me (after reviewing previous work orders), is when the IPMA was replaced the work order notes that the reprogram failed due to low state of charge of the battery... this leads me to believe that the service dept. is either unaware or is ignoring the requirement of external 12V supply to do updates. Maybe the IPMA doesn't require it, but it is worth an eyebrow raise.
To be clear, most of the hybrid components are on a discrete, low temp cooling loop. If needed, the AC is used via a plate heat exchanger to provide additional cooling. The electric motor on the other hand is cooled via the trans fluid. From everything we've seen thus far, the transmission overheats before the emotor does. You're the first case I've heard of anything in regards to the emotor temp. Given the long list of codes previously seen, it sounds more like a GWM issue.
The IPMA programming killing the battery is due to incompetence on the tech that did the programming. He didn't use a proper power source on the 12v system. About the only thing that tells us is that they're not using the brightest lightbulb on your truck.
