Mobile Hotspot antenna and range
Davexxxx
MO
I will say that the trucks hotspot is mostly only useful inside the truck; its strength fades quickly outside the truck.. don't expect to sit at your campfire and use the hotspot unless you are parked very close by, or have just the right angle / position.
ATT say its good for 50'. Not true?
Samson16
Samson16
Orlando, FL.
Aviation systems
I also use T-mobile, via Google Fi (unlimited), but I pay for the in-built ATT hotspot, as the coverage in some remote areas is better. I will say that the trucks hotspot is mostly only useful inside the truck; its strength fades quickly outside the truck.. don't expect to sit at your campfire and use the hotspot unless you are parked very close by, or have just the right angle / position.
Gotcha, but while we're traveling it works pretty well (y)
travisN000
Travis
Oregon
2021 F150 Powerboost CCSB
I would say it depends... I've had times where I can be that far from the truck and it works well; at other times I have to be sitting in the truck, or very near by. I don't know exactly where the Wifi hotspot antenna is, but my guess is that its inside the vehicle and the metal body panels block some of the signal (pretty sure the fins on the roof are only for the cell and satellite radio signals).
You will definitely find dead spots inside of a 50 ft radius, but I think it depends on what there is for the wifi to bounce off of as it exits the glass panels; pretty sure it doesn't penetrate aluminum body panels well.
ColoradoHunter
Dennis
2021 F150 King Ranch 4x4
I use the hotspot with my laptop when I'm camping. Truck parked 10" or so away and using the laptop inside my camper. It works fine. Range could also be limited by what you are using, laptop or cell phone.
gregs150xlt
Tennessee
2023 Ford F150 XLT
Thanks! I'm wondering if on trips the Ford supplied onboard cellular hotspot setup is worth the monthly charge. I don't need to pay for myaccess features like remote start etc., and I am considering adding a cell booster to the vehicle but I do not want to drill holes in the cabin. Magnet mount antennas don't work for f150's either, so the service charge payment to avoid drilling and mounting things is worth at least checking out imo.
the "hotspot" is only $20 a month for unlimited data. It runs off AT&T. I have had absolutely no issues with reception, but you would need good AT&T coverage.
gregs150xlt
Tennessee
2023 Ford F150 XLT
Just call ATT car services and tell them you want your unlimited plan back. They'll then ask you what plan it was and you tell them it was the $15/mo unlimited. You had to replace your lost card and it just canceled the service. They don't keep records and they'll put you on unlimited for $15/mo w/ auto billing. It's cheaper than yearly and if you do cancel your card, it will remain on for 2 months before being shut down.
there has NEVER been a $15 plan (that I've seen).
the plan is normally $25, but if you wanted to extend the trial, you could get it for $20 within a two day period. (This applies for a 22 or 23 Model year).
DcnPat
Patrick
Alexandria, VA
2016 Jeep Wrangler 2022 Subaru Outback
IT
If you pay a full year up front $200 / 12 = $16.67/month
Samson16
Samson16
Orlando, FL.
Aviation systems
Yeah, you're right....
Ford F-150 Mobile Hotspot antenna and range 1687464097804
Or you could do what I said
Or $200 annual = $16.66 (a bit creepy, I admit)
gregs150xlt
Tennessee
2023 Ford F150 XLT
HMMM, $15, eh? I've certainly never seen that (well with Nissan or Ram that is)that certainly must have changed with a 2023 Model Year. How long have you had the $15 plan?
Well, its $25 now, unless you accepted the $20 at signup. . . . . . Seems new model year subscriptions get screwed on almost everything.
gregs150xlt
Tennessee
2023 Ford F150 XLT
Well, if you don't sign up on the Annual plan, its normally $25 (unless you accepted the $20 a month offer when you signed up).
So, the annual plan is cheaper, on a 2023 model year anyway.
Steyreo
Brian
Pacifica, California
‘21 Lariat SuperCrew PowerBoost Sport Fx4
Somebody should point out to the op in case they didn’t know that you can’t have CarPlay and use the truck Wi-Fi on the same device. @Samson16
Samson16
Samson16
Orlando, FL.
Aviation systems
I'm aware. Since my device is busy with CarPlay, I want the wifi for our laptop or ipad air. She's using her phone right now but she wants to use the laptop without bothering to use her phone as a personal hotspot. I want her to be happy while we travel together :)
This also diversifies our coverage since we both have the same Tmobile plan.
I've spent way more than $250 on actual useless stuff before. This isn't even close to a bad purchase for me lol.
